YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 11-12-2015, 02:09 AM
  #6316
DirkW's Avatar
Originally Posted by niznai
I think the short shock upgrade existed in the past as an option.
Yes, but the older short shocks were smaller in diameter.
DirkW is offline
Old 11-13-2015, 12:50 PM
  #6317
Trader Rating: 1 (60%+)
Will the new car work better in slower classes? Is there a price on the new kit or conversion?
racer034life is offline
Old 11-13-2015, 12:58 PM
  #6318
DirkW's Avatar
Prices have been posted within the last couple of days on this very thread - and since it's not out yet, people here haven't driven it yet.
DirkW is offline
Old 11-13-2015, 03:20 PM
  #6319
I really want to try the nee car in 17.5. I've never owned a Yoko. Can anyone give me some feed back on how the old car was in 17.5
Old 11-13-2015, 03:23 PM
  #6320
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Yokomo BDs have always been awesome in stock or mod
As are most other leading cars
RedBullFiXX is offline
Old 11-14-2015, 11:04 AM
  #6321
Here in the mid-west we don't see many guys racing with the yokomo's in slower classes. This is why I was asking the differences in handling between the 2015/16 cars. I want to try either car to see how they handle
Old 11-15-2015, 08:20 PM
  #6322
policeman0077's Avatar
A newbie question
Is there a way to take out the bearing in the steering and replace them? Or it press fit and u need to buy the whole steering assembly?
policeman0077 is offline
Old 11-15-2015, 08:47 PM
  #6323
niznai's Avatar
Which one? Cranks or rack?
Never mind, they're all replaceable, you just have to fiddle a bit.
niznai is offline
Old 11-16-2015, 12:29 AM
  #6324
Originally Posted by policeman0077
A newbie question
They are replaceable but rather hard to remove original ones especially if you do not have a press. They fit tightly! New ones will slip in no problem once you remove the original ones. I had to heat mine to get it off. Be aware once you heat you will loose the blue ionisation colour - it will turn silver! Good luck.
P.S. I changed bearings on mine as I needed a quick repair, but ordered the new steering parts and had them replaced anyway. its up to you though.
buzz777 is offline
Old 11-16-2015, 05:50 AM
  #6325
RC295's Avatar
Default Yokomo BD7 Direct Mount Servo
just want to know if Yokomo BD7 Direct Mount Servo can be used on BD7 2016// ty for info
RC295 is offline
Old 11-16-2015, 09:26 AM
  #6326
reg
It can as one of the deals is with one in the kit 👍🏼
reg is offline
Old 11-16-2015, 04:32 PM
  #6327
RC295's Avatar
worth to buy it or better stick with futaba or sanwa servo?? need review on this servo
RC295 is offline
Old 11-16-2015, 09:40 PM
  #6328
niznai's Avatar
Are you sure it's tightness and not some bonding solution? You might be able to use acetone and let it sit for a while to make sure the bonding agent is dissolved. Or if you want to avoid losing the colour, you can try freeze and release, it's liquid nitrogen in a can. Spray the bearing and it should drop out.
niznai is offline
Old 11-16-2015, 09:43 PM
  #6329
niznai's Avatar
Originally Posted by evochick
Internal ratio is staying at 2. 17T pulley and 34T diff/spool.
Will be interesting to see if the older 20T pulleys will fit with the new motor mount and topdeck, that will take it out to 1.7, but the other issues is the pulleys then might not fit.
When did it change? The first BD7 (2014) had 41 tooth diff crowns. Did it change when the new diff came out? That's probably the smallest diff tooth count on the market right now (and seems pretty small at that).
Personally I prefer an irrational internal ratio otherwise you'll have the same tooth and the same belt tooth running in all the time. Something like 19/37. Even these have at some point a common multiple, but in my opinion it's better for longer lasting drive trains.
niznai is offline
Old 11-16-2015, 10:05 PM
  #6330
CristianTabush's Avatar
The BD7 has always had 20/40T pulleys. They changed to a new diff case with the '15, but kept the 40T diff size. It is not until now that they are changing them.
CristianTabush is offline
