YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 06-16-2014, 04:09 PM
  #4171
miller tyme's Avatar
Originally Posted by Carranza76
Looking for a good gearing suggestions for 17.5
Running the following:
Tekin Gen2
Reedy 17.5 first Gen motor
Right now I am geared 116/38
I am new to on road so is there a FDR I should stick to with this car? any help would be greatly appreciated.
I'd start around a 3.85-3.95 watching temps and I'm assuming Blinky with motor timing cranked up
miller tyme is offline
Old 06-16-2014, 04:14 PM
  #4172
Carranza76's Avatar
Yes blinky with timing cranked up. Much appreciated!
Carranza76 is offline
Old 06-16-2014, 06:34 PM
  #4173
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
That 116 spur is for mod
You will need a smaller one for 17.5
Try a 96 spur
48-50 pinion
I would also recommend an R1 fan to keep temps manageable
RedBullFiXX is offline
Old 06-17-2014, 07:28 AM
  #4174
Carranza76's Avatar
Try a 96 spur
48-50 pinion
I have a fan on it. Tekin fan that i bought a long time ago.
I saw a set up with a 115/38 and one with a 108/34 (something like that)
So i thought I could make it work, Plan on hitting TQ tomorrow night for my fisrt run. Hopefully I can get the spur/pinion I need from there to put them in real quick.
Redbull I sent you a PM.
Old 06-17-2014, 07:49 AM
  #4175
I saw a set up with a 115/38 (6:1) and one with a 108/34 (6.3:1) (something like that)
Seems most 17.5 racers are recommending something in the range of high 3:1 ratio. (3.9:1) thru (3.7:1)
Look at the last page of your BD7 instructions
There is a gear chart
Old 06-17-2014, 10:43 AM
  #4176
Raman's Avatar
Trader Rating: 94 (100%+)
Installed front stabilizers on my RS today. Unlike the rear the front has all the necessary hardware.
Its interesting that the blue anodized pieces in this kit vary so drastically in colour. One piece is close to associated blue and the other is almost indigo blue.
Raman is offline
Old 06-17-2014, 04:50 PM
  #4177
evochick's Avatar
finally got a chance to drive and make some setup changes everyone suggested a few weeks ago, and I really wish I listened to Craig at the time
The 15gram weights on both sides at the front make a huge difference, turn in was certainly improved, and felt more stable. oh well you live and learn...
The other change I mage was to move the front arms full back with the 1mm shim at the front, I think this just helped overall rotation.
If like me you think paying $30 for the Yokomo weights is a bit silly, a 10g and 5g lead weight fit perfectly, the only advantage the Yokomo weight would be is its screwed in.
Beth.
evochick is offline
Old 06-17-2014, 06:17 PM
  #4178
Beth.
Cool
Old 06-17-2014, 08:30 PM
  #4179
JimmyMac's Avatar
Not only are the front weights screw in, they are floating as well. The only point they touch the chassis is where they screw into. The rest of the weight floats above the chassis so as not to alter flex.
JimmyMac is offline
Old 06-17-2014, 09:04 PM
  #4180
hanzo3's Avatar
Trader Rating: 55 (100%+)
Yeah they are nice. But $30 nice? Does 3racing or anyone else make similar weight that can be screwed in?
hanzo3 is offline
Old 06-17-2014, 09:18 PM
  #4181
niznai's Avatar
I guess there is a lot of part snobbery here. I don't see why one can't use some bland piece of metal with a threaded hole ground to size and screwed to the chassis using a small spacer (or a shim) if chassis flex is a concern (which I don't think it should be). Or just a screw with a nut and a number of oversize washers. Much easier to tune as well by adding or taking away washers. Or just good ol' wheel balancing weights with double sided tape.
Of course this is not going to increase sales of nicknacks from major manufacturers at overinflated prices.
niznai is offline
Old 06-17-2014, 09:24 PM
  #4182
JimmyMac's Avatar
Expensive, but a typical price for brass weights. Just look up Serpant and XRay prices for their brass weights. These weights are from the BD5 days, so if you had them laying around they simply bolt into this car. But yeah, if you don't want to spend the money then just get the 3Racing graphite looking sticky tape weights. Cheap and easy. That's what I use under my Rx.
JimmyMac is offline
Old 06-17-2014, 09:27 PM
  #4183
JimmyMac's Avatar
Basically put, it's just a hobby. Customize and tune as you see fit.
JimmyMac is offline
Old 06-17-2014, 09:35 PM
  #4184
JimmyMac's Avatar
Any Yok drivers run the Sweep 36's from the Reedy Race? I was just wondering how they perform. I was wanting to try some this weekend against my Sorex 36s.
JimmyMac is offline
Old 06-17-2014, 10:23 PM
  #4185
Raman's Avatar
I personally prefer Sorex to Sweeps.
Raman is offline
