YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 09-27-2012, 10:26 AM
  #391
NolanP's Avatar
[QUOTE=Jampot;11260316]
Originally Posted by NolanP
I will show you the link. It lists 39.5 arms and just regular arms two different part #'s.
BD-008R assuming (based on graphite) 40.5--this is what the car comes with
BD-008R1 39.5
non-graphite lengths
BD-008RG 40.5
BD-008RG1 39.5
graphite lengths
That's what I thought philipp, Nolan the RG stands for rear graphite I think, the R is standard plastic. The base setups are 39.5 for both carpet n asphalt so assumed it had the 39.5 as standard.
Obviously I don't have a bd7 "yet" but do u get extra pivot blocks in the the kit only on petit Rc I think I saw parts list, the parts that are optional have a star by but there was 2 I believe front front pivot blocks without star so assume u get extras in kit.
Thanks Jay
Look it up BD-008R is a standard 40.5mm arm
BD-008R1=39.5mm standard arm. BD-008RG is 40.5mm graphite. BD-008RG1 is 39.5mm arm graphite.
There are four arm options.
NolanP is offline
  #392
If they are what's the difference? Why is there the R vs R1 when both are 39.5?
BD-008R is 40.5mm
BD-008R1 is 39.5mm
Yes i´m sure because i´ve measured it! ;-) I´ve got the plastic kit arms and also the graphite arms, both are the same length...
So i don´t know why there a two different numbers... But i´m sure that the kit arms have 39,5mm... And that´s what the team is running and everything you´ve need! ;-)
Philipp1990 is offline
Old 09-27-2012, 11:26 AM
  #393
Where to fine yokomo tire addctive?
Zooberg is offline
Old 09-27-2012, 11:29 AM
  #394
nice kit.. you know where i can get one in Canada?
rcguy888 is offline
Old 09-27-2012, 11:52 AM
  #395
B00t13g's Avatar
Has anyone found the aluminum washer for the spur for sale?
B00t13g is offline
Old 09-27-2012, 12:15 PM
  #396
NolanP's Avatar
Lol you too huh? I found a Hot Bodies piece that works other wise you have to order BD-644 according to Pro Shop Futaba. HB #68723.
NolanP is offline
Old 09-27-2012, 03:54 PM
  #397
[QUOTE=NolanP;11260388]
Nolan u are spot on strange why
008r is 40.5
008r1 is 39.5
Then 008r2 is 41.5
u would have thought that they would have done it in order that's my fault sorry
What thickness is the chassis and top deck please?
And also do u get extra pivot blocks in the kit?
Regards Jay
Jampot is offline
Old 09-27-2012, 04:56 PM
  #398
B00t13g's Avatar
Lol yup. I ordered the hb parts!
B00t13g is offline
Old 09-27-2012, 05:03 PM
  #399
NolanP's Avatar
[QUOTE=Jampot;11261489]
008r is 40.5
008r1 is 39.5
Then 008r2 is 41.5
Regards Jay
Havent measured the chassis(Yokomo website 2.25) or deck.
Zero extra pivot blocks. No extras. I pretty much carry around a small parts store of stuff. The stock stuff is pretty good but a decent hit running mod expect to go through Carriers. I have gone through one front and one rear in one week. My Dcj came apart but thats my fault for not removing the screw and adding lock tite. In turn it took out my front carrier. The second one I got hit in the wheel. It was enough to crack the wheel as well as the carrier obviously.
Things I would buy
Spare Arms
Carriers
Hubs
Hinge Pins
Kingpin screws
and that stupid Spur Collar...lol (although I have 8 of the HB part# now)
NolanP is offline
Old 09-27-2012, 05:25 PM
  #400
B00t13g's Avatar
Some how I managed to strip steering blocks with very light hits.
Do the graphite ones hold up better? They're just stripping the lower king pin screw out. I've gone through 3 individual ones so far and I'm down to one spare until my next Rc market order comes in that hasn't left Hong Kong yet.
B00t13g is offline
Old 09-27-2012, 06:01 PM
  #401
NolanP's Avatar
I have my last day of Asphalt on Sunday so I am saving the graphite stuff. How tight are you tightening the kingpin screw? Are you going till it mates in and there is no gap? or are you tightening it more?
It is a softer material so you shouldn't be going too tight or it will stretch the polymer material causing premature failure.
NolanP is offline
Old 09-27-2012, 06:31 PM
  #402
A Ilievski's Avatar
Trader Rating: 39 (100%+)
It is a common problem with the plastic parts, once you change to carbon parts you wont have this issue.
A Ilievski is offline
Old 09-27-2012, 08:20 PM
  #403
B00t13g's Avatar
Should I just run all carbon plastics then?
B00t13g is offline
Old 09-27-2012, 09:20 PM
  #404
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Yes, they are much better for pretty much all track conditions. There is a reason the team uses them, just look at the words, everyone used them and that was low grip asphalt
Yokomo_Ant3 is offline
Old 09-27-2012, 09:25 PM
  #405
B00t13g's Avatar
This learning curve sucks.
B00t13g is offline
