YOKOMO Touring Car BD-7
#1561
Hi all I am new to this thread but I want to order a yok DB7 what spare parts or hop ups should I order with this car I normally run 12 scale and world gt so I have no clues on what will break or wear out my home track is universal speed way I know there was one other DB7 at the track I watched the video it looked impressive so any help would be appreciated thanks
Gabe
Gabe
front spool cup and some c-blade for rear geardiff and some c-hub too if you crash alot.
#1562
Hi guys,
My name is Bill and recently I purchased my BD-7 from my local Hobby store.
After reading most of this .. large thread I have taken many valuable screenshots of tips and tricks you have been posting throughout the forum; but I'm here now to ask for a general overview of what should and shouldnt be done in order to have a car that is good through the corners and agressive down the straight.
Being that my first car was a Hyper 10 - I've learnt to race aggressivly all my life. now racing the Sakura S Zero down at the track every fortnight, and starting to win races I thought I'd go and buy myself an upgrade.
After reading this forum I learned that this car is not for the aggressive driver; which is a good thing and a bad thing. This is good because it can eventually teach me a smoother driving style, conserving more battery for my races and performing better overall.
I know how to setup my car and I know how to drive, but being a totally different car to what im used to I thought id come here and ask for some advice.
I have already put my car together with no difficulties ready to run on my indoor Bitcherman track; with the book setup and a 5.5 turn motor. I WILLNOT be using this motor for long at all as this is rediculacly crazy on this car. I am waiting on an online order with a new server + 13.5 motor. I am running sorex 28R tires with the soft (pink) Inserts, which usually works well on this track.
I will be running this car for the first time on Tuesday and hopfully everything goes well. I am posting this now so if there is anything important that I should know - I can make changes beforehand
Thankyou all in advance
Bill
Bill
#1564
Gabe
Gabe
If you use the stock front cvds, you will notice that they will chatter violently when turning. If u like to drive with drag brake, it will have the same effect entering corners.
The Yokomo double joints from what I hear are terrible...dont buy them.
The spec r v2 bd5 double joints are a direct fit. So I would recommend them.
I use Tamiya double joints (which are based on spec r v2s) with tamiya graphite steering knuckles. Work flawlessly.
List:
Yokomo Front Steering Hub Carrier YO-B7-413W
Yokomo Front Graphite Suspension Arm BD-008FG
Yokomo Rear Graphite Suspension Arm BD-008RG
Yokomo Rear Graphite Hub Carrier BD-415RG
Yokomo Spool Outdrives Steel B-046
Yokomo Short Kingpin Set SD-414S
Yokomo Graphite Steering Block BD-415SG
Yokomo King Pin BD-414B
Yokomo Ball Stud L ZC-206LH
Recommended upgrades:
Yokomo Front Upper Bulkhead CSO BD-7006
Yokomo Alum Rear Hub 0 Deg BD-415A00
#1565
Hi guys,
Bill
Bill
Ive had my car react both ways depending on traction. We too use sorex 28s at our track.
if your track has medium to high bit, you can easily have the BD7 drive aggressively without being twitchy. if the bit is low, the BD7 will Flow around the corners more.
Another tip to make the BD7 more aggressive:
BD7 has a lot of inherit body roll compared to others like the s411, T4 etc, so make sure you run light weight body, especially if you are running a Speed 6. if you run Reg weight, make sure the body is slammed, well slammed enough so your front tires clear the wheel well when turning. A taller body definitely makes the BD7 look and feel lazy around corners.
#1567
BD7 has a lot if inherit body roll compared to others like the s411, T4 etc, so make sure you run LW body, especially a Speed 6. if you run Reg weight, make sure the body is slammed, well slammed enough so you front tires clear the wheel well when turning. A taller body definitely makes the BD7 look and feel more lazier around corners.
The lexon is coming in on 0.75mm thick. I've used this body on all my cars before, and the aero + downforce on this is amazing
#1568
looking at some pics, the STRIKER SR looks closer to a LTCR. so chances are it will be an aggressive body. If you find that your BD7 is ass happy, raise the front shock tower position up one or 2 spots. Try the setup I posted up, as most setups available that people posted are generally the same.
are you running front Double joints? Because your car will handle a lot differently depending if you are or not.
#1569
I've only tried the Mazda 6, Mazda Speed 6, and LTCR.
It's good to hear that my body should be fine as well!
Also. Where can I find a copy of your setup sheet? I would greatly appreciate having a copy of this!
Thanks again
Bill
#1570
Everything is stock right now except for the urethane bumper and a mod motor. Therefor I am not using DJB in the front or rear. I've had a look at these and it is nearly 150$ for a set of 4... Is it reall worth it?
Thanks again
Bill
Thanks again
Bill
http://www.petitrc.com/reglages/yoko...ceway20130113/
I highly recommend you get graphite arms, steering knuckles and rear uprights on carpet. even better O deg, rear aluminum uprights for more corner speed and durability. Leave the C-hubs as reg plastic.
You only need Double joints for front, NOT rear.
Get these:
http://www.spec-r.com/default/index....roducts_id=245
Yokomo OEM Double joints are weak and come undone apparently.
you will notice that the stock CVDs for front will chatter violently. It will give you a drag brake feel entering corners. when you get Double joints you will carry speed into corners.
#1571
Get these:
Get these:
How are these in terms of quality?
Also, where do you get them?
#1572
I just fitted a pair, will be trying the car with them tomorrow.
The pins are 2mm, the std Yok pins are 2.1mm, so they're a little slack in the spool outdrive. It's disappointing really because it's a very simple thing to get right, if I can measure them then surely Spec-R should be able to as well...
It's also a shame because otherwise they seem quite well made. Maybe they fit their own spool better.
#1573
I've never tried them, but reading this thread, people who use them are happy.
The Spec R V1's were weak. any tap would break them.
Version 2 has heftier dog bones and Joint piece.
The only problem with spring steel is that it has no give. so with enough force it will snap.
I really like the Tamiya DCJs as they are same design but made of steel. wont snap, very durable. I've owned tamiya DCJs since they were released, still have never broken a set.
do a google search.
TQracing online site says instock
do a google search.
#1574
If you find your Stricker body too twitchy at your Med - High traction track, run a Speed 6 body. that will tame the beast for sure!
#1575
Hi Bill, where are you located and what track do you go to?
