Yokomo MR4TC-BD
#9032
do u have pics of it at full lock?
#9033
#9034
Sorry i dont. You can also use an xray knuckle. But the bearings become an issue. I think i used the std inner, xray outer, with a shim on the oustide of the bearing, but on the inside of the pin. You will know what i mean if you try it
If you use the tamiya centre steering piece, you will need slightly longer steering turnbuckles With this steering mod the outside wheel at full lock almost hits the shock I havent measured the inside wheel lock, but its around 1-2d less than my Xray T3. Which had 31 when i last measured So around 29-30 on the inside wheel i would say
#9035
Hi for Lock The Stearing in my BDM i Use the Hot Bodies Cyclone C-Hubs And modify The Yokomo SD-202G Steering bellcranks, whit the Yokomo BD hackerman Plate upside down Installed.
Itīs very easy
Itīs very easy
#9036
#9038
Do u guys have a list of lipo batteries that will fit in the lipo/stick pack brace without modding anything
I know trakpower,and checkpoint lipos fit without modding anything
#9039
Kriss Itīs The Same of Picture yo go uploaded than the Criss Grainger In Euros. I mount the same configuration Than Cris Grainger In Euros.
#9042
hey guys looking for a 1.5 Deg. rear toe block for the yokomo BD/SD
looking for pics too
lmk what u guys got
thanks
lmk what u guys got
thanks
#9044
#9045
Anyone know what is the brand of this servo horn and parts number??
[/QUOTE]
[/QUOTE]
