Yokomo MR4TC-BD
#8222
will associated springs work on the shocks ?
and thanks for the quick answer on the pistons
#8224
Does anyone know if they make a 0 degree for the rear on the bd and if so can someone give me a part number
#8225
as for a 0 deg rear toe block, the dont make one in alum that i know of you i know you can get a 1deg from the SD but i dont know the part # ( you may be able to use the Rear front suspension mount in both the rear front and rear rear. but i am not positive.
#8226
they make a 0 deg rear hub carrier, ( it comes with the 1 deg steering knuckle part # sd-415 i think)
#8227
When fitting Cyclone C hubs to the BD, do you need to use the Cyclone hinge pins, or can the yoke ones still be used? Same questions also for the kingpins?
When fitting the yoke steering knuckle to the Cyclone C hub does it need shimming and if so, above or below the knuckle?
#8228
HPI C HUB FITMENT
JJC,
I used the cyclone hinge pins and also used the small grub screw to hold it in place. This fits into the bottom of the cyclone c hub. I dremeled the yoke arms to 2.5mm for this work. You can not use the yoke hinge pins as they are only 2mm diameter.
I used the Yokomo O front knuckles and placed the cyclone top hat internally in the c hub at the top, I also used a shorter screw. For the bottom I fitted the cyclone top hat from the bottom of the c hub. Does not go internally on the c hub. You may have to shave a small amount of the top of the yokomo knuckle.
Just ensure that you have no binding when fitting.
CYA
Calvin.
CYA
Calvin.
#8229
Thanks for that
#8230
:sneaky:
I just finished building it last night...
SIKE
SIKE
#8235
can i just ask does anyone actually have an idea why he was using the cgm arms?
