Yokomo MR4TC-BD
#4831
Yok uses 2mm outer hinge pin, TC4's is 2.4mm. You may need to enlarge the holes on the Yok's arm.
#4832
Originally Posted by Ali Graham
Ok I've just compared the 2 together. The tc4 hub is slightly lower, and when installed it would be in a similar postition to the yok one if there was a hole in between the upper and lower holes, if you get me. Basically if the top hole is too extreme for you and the lower hole is too unresponsive on the yok hub, use a tc4 hub Doesn't appear to need any mods, but the hingepin hole looks a little bigger so there may be more slop with the yok hingepins.
I'll give them a try outdoors this weekend.
#4834
All it needs to work is:
Drill front arm outer hingepin holes to 2.4mm (2.5 works fine) and use TC4 outer hingepins.
Place a shim under the kingpin on the top of the c-hub (because the tc4 c hub is thinner this is needed for the kingpin to secure properly)
A 1mm shim to go on the outer hingepin, because the tc4 c-hub isn't as wide as the yok hub. To achieve the same camber link angle, place this shim behind the hub, but I might try it in front, which will move the outer end of the links rearwards (hard to understand I know!)
I got mine to fit properly and I'll let you know if they're any good or not.
#4835
Trader Rating: 51 (100%+)
Does anyone know the spring rates in Lbs for the New Yokomo white springs?
#4839
Originally Posted by v0rtex
I have my own memorial wall with a busted chassis, two busted top decks, a snapped front shock tower and a busted ackerman plate on it
ouaouuuuuuuuu !!! I am sure that this wall must be destroyed!!!!
#4840
#4841
Originally Posted by Jochim_18
ok guys I had a bad crash last race, I cracked the front end of my chassis. So instead of buying a stock Yok BD chassis, Does anyone here know where I can get a different chassis here in U.S?
#4842
Originally Posted by hurley081182
he used a novak fan and a motor heatsink and looks like he just got some wires and tied it that way. if you look at this picture you can see what you are talking about alittle better. it is in the right corner of the picture.
http://www.rc50.com/modules.php?name...bum=25&pos=109
#4843
#4845
is this the page you mean:
http://www.fibre-lyte.co.uk/
can you send me pics my email is [email protected]
thanks,
matt
Originally Posted by pops
I have a BD 3mm custom carpet chassis for sale if anyone is interested? $85.00 US
thanks,
matt
