Yokomo MR4TC-BD
#4727
Originally Posted by smojoe
any BD guys going to the carpet nats in stockton?
I don't wanna be the only "yokomo" guy there
#4728
Originally Posted by pops
What foams are you running? I found that the Parma foams fit without narrowing, and the rim won't rub the steering arm. But, with the new ROAR tech box, the car will not slide in because the front trac is too wide. I took the hex hubs and have removed about .5mm off the outside of the hub. This should make the tires set in closer to the chassis and allow the car enough room to side in the tech box. Only problem; is that the tires now rub on the steering arm. I then removed about .7mm off the inside of the front tires and rim so they won't rub. Hopefully the car will now fit in the box, will see this Wed. I think the JACO rims may have a little less offset and may work in the tech box, without modifying the hubs. But you would still need to narrow the fronts to keep from rubbing.
#4729
Originally Posted by mush104
hey everyone i was wondering if some of you could give me some setups for rubber tires and it should be a med. to high bite thanks
try the one 3 or 4 posts back
#4730
Anyone have experience to fit the 415's white belt to BD? Thx
#4732
Anyone have any more info about the Masami edition of the BD? Like when it will be available here.
#4733
The 415 belts don't fit, different number of teeth.
The Masami car comes with
new design front shock tower - lower than original
new design rear shock tower - higher than original
All carbon - wishbones, castor blocks, front and rear hubs
1 way centre pulley and front
Titanium screw set,shock shafts, hinge pin screws
Precision bearings
I'm pretty sure that it doesent come with the bomber belts
Its very similar to the Grainger kit available in the UK whith the above mentioned changes. Don't worry if you have bought a Grainger kit as nothing is really that different. In fact I would recommend the Grainger kit as its more to spec with the parts that we actually use outside.
As far as I'm aware CML are not looking to bring the Masami kit into the UK, the Grainger kit is more than sufficient.
Precision bearings
#4734
Originally Posted by crabboy
No need to fit 415 white belts as Team Bomber make white belts to suit the BD.
I have been running them for a while and are working great so far.
#4735
hey some good news, saw billy building his new car at socal today.
#4737
yep
#4739
Originally Posted by v0rtex
Awesome! When did he come back to Yokomo?
Great to see him back on a Yokomo.
#4740
Hi guys. I am looking at getting a new car and I would like to know what you guys think of the Yokomo BD?
