Trinity duo3.5 new motor >
Old 12-03-2012, 09:42 PM
  #541
Trader Rating: 20 (100%+)
Originally Posted by nexxus
So the D3.5 isn't going to be any better than the D3.0? Whats this with stores advertising it as a 3500kv 17.5 Motor as well?
D3.5 is an update! It should perform as good or even better than its previous counterpart. As for your other question, 3500kv is what Trinity rates the motor at.
goots is offline
Old 12-03-2012, 09:46 PM
  #542
LonnyJ1950's Avatar
KV ratings are the most useless piece of info out there. There is no standard way to measure. In my 1/12TH scale the 3.5 is definitely faster than the 3.0. But each motor is a little different and you need to sort out your own timing and gearing. Anything you read here is just to get you in the ballpark. Find a motor you like and dial it in.
LonnyJ1950 is offline
Old 12-03-2012, 09:48 PM
  #543
I)arkness's Avatar
thats what its suppose to be as advertised on the trinity website. and if you get the other rotor its suppose to bump the 17.5 from 3500kv to 3800kv.
now that you mention this, might test it on my friends speed passion dyno to confirm the ratings
I)arkness is online now
Old 12-03-2012, 10:16 PM
  #544
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Just seems that guys are using Novak and Turnigy 17.5's rated at 2200kv area and gearing at FDR 3.5-4.0 by that logic if I get a 3500kv Trinity and gear at FDR 3.5-4.0 I should be almost twice as fast.
...which I doubt.
nexxus is offline
Old 12-03-2012, 10:21 PM
  #545
I)arkness's Avatar
one trend ive noticed is that people running say a reedy or other motors with lower Kv specs not trinity gearing in the 2-3 range, and myself having ran from 3-4. and getting both top and bottom end. Mind you this is in F1
Old 12-04-2012, 12:43 AM
  #546
+1 Lonny. I know I didnt want to answer the KV question because I know some people just dont get it
gear to the style of the track, make sure temp is in check, and drive the crap out of it. Forget the numbers....
goots is offline
Old 12-04-2012, 06:27 AM
  #547
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
KV Rating is right up there with "C" ratings as far as useful information
RedBullFiXX is offline
Old 12-04-2012, 08:40 AM
  #548
Not sure if this was asked,Is there a certain speedo that works best with this motor in 17.5 blinky touring car?
John Piper is offline
Old 12-04-2012, 12:02 PM
  #549
Jerz616's Avatar
Trader Rating: 49 (100%+)
I'm using an Orion R10pro and its awesome.
Jerz616 is offline
Old 12-15-2012, 08:29 PM
  #550
Trader Rating: 19 (100%+)
Can someone tell me what the factory timing is set to on the D3.5 21.5 motor is?
429racer is offline
Old 12-16-2012, 05:48 PM
  #551
SS LS1's Avatar
Trader Rating: 23 (100%+)
The motor should come set on the 0° timing mark, but remember at that setting there is 30° of timing built in already. So if you advance the endbell to 20° your motor will be at 50° total timing.
SS LS1 is offline
Old 12-16-2012, 06:52 PM
  #552
Nice to know this information. I keep hearing about the endbell in the 3.5 needing some sort of modification?? Is this true??
Does the D3 at the 0° timing mark have any built in timing??
Sorry for the newb questions, getting back again into electric TC.
Serpenteer is offline
Old 12-16-2012, 07:14 PM
  #553
Trader Rating: 280 (100%+)
When they first came out, they were modifying the end bell to get more timing not realizing that it was already capable of 50*. 30* built in and going up to 20 and stopping there. After they modified and went to 70-80* and smoked a few motors, they suddenly found out what they did was cause more harm! There's a reason why they stop at 25* on the end bell!!!
Don't know about the D3. Never had one.
Andy Koback is offline
Old 12-17-2012, 09:34 AM
  #554
kewdawg's Avatar
I believe the D3 has 30* of timing, also.
kewdawg is offline
Old 12-17-2012, 09:59 AM
  #555
AdrianM's Avatar
...and the Revtechs too. However, the Revtech Endbell was slotted to give 5-10 deg more timing than the D3's.
AdrianM is offline
