-   -   Futaba receiver linking problem :( (https://www.rctech.net/forum/electric-road/630195-futaba-receiver-linking-problem.html)
Infinite 12th 05-20-2012 05:25 PM
Hi, I have a Futaba radio and when I try to link it in M2 mode it blinks read not solid green as it should. It starts out blinking green. There is also no troubleshooting for blinking red
Trans: 4PL
Receiver: R2104GF
For my sedan in M1 mode it links fine but my receiver in my 12th is not working
Brand new receiver hooked up to LRP stock/spec
Anyone experience this problem
joelwhite 05-20-2012 05:32 PM
Not to ask a stupid question, but you have the radio on transmit(the blue light). Not the test on(red light)?
Infinite 12th 05-20-2012 05:40 PM
Yea and two other people who had futaba radios tried to help me, also with no luck. In fact one guy actually tried to link to my receiver and couldn't...lol
Thanks though
Andy Koback 05-20-2012 05:52 PM
Trans: 4PL
Receiver: R2104GF
On the sheet I have for a 603FS receiver, "Blinking Red" means "PCM is improperly selected".
That may have to be changed on the M2 mode?
Infinite 12th 05-20-2012 06:59 PM
Looked for PCM and couldn't find it on Transmitter or manual
Thanks though
MAD916 05-20-2012 07:42 PM
look in menu for a selection called "mode" and try it in either PPM or HRS mode think you'll have to power off the transmitter after making the change to store the setting changes. sometimes with certian receivers that will work, but have also seen where they just wont bind up.. had it happen a couple weeks ago when one of our guys tried to seel his old 3PK and it would not bind with a newer style receiver no matter what mode we tried.
Infinite 12th 05-20-2012 08:13 PM
Thanks, did not see PPM or HRS. It is the same receiver that came with unit. Maybe it's a dud...lol
It's probably cheaper to buy new one than send to Futaba I dunno
Infinite 12th 05-21-2012 05:32 PM
Fixed
Put Transmitter antenna right on receiver antenna wire and it worked :lol:
At 3 inches I was too far away I guess...lol
:deathstar
FFred 05-22-2012 01:41 AM
:deathstar
Where did you tried it ? Are there other system turned ON ?
I think Futaba says that you need to be in area without other RX and TX turned ON when you bind yours.
Infinite 12th 05-22-2012 07:29 AM
Failed at track, tried at home and worked. No other RX or TX on. Just had to get super close not like my other RX that binded a couple feet
Problem solved for now :ha:
Andy Koback 05-22-2012 10:34 AM
Didn't think They had to be that close together to bind. I could see 3 feet! 3 inches??? What happens on the track, does it receive okay?
Infinite 12th 05-22-2012 10:09 PM
I had given up then saw my 12th on my dresser then thought hey why not try really close then it worked :sneaky:...lol
Haven't tried it yet on the track :confused:
I'm sure it will receive fine now that's it's linked but if not will post
Deja Vu 05-23-2012 04:50 AM
I had a similar problem with a new 4PL recently. Here at home, it linked up just fine with the S-FHSS receiver that came with it, but after trying for over 90 minutes, I couldn't get it to link with a slightly older FHSS receiver. I had it set correctly, but it just wouldn't link. Took the set up to the local Hobby Town and it linked first try. I have since moved electronics around and had the situation show up again. This time, when I switched linking from S-FHSS to FHSS, I shut off the radio and let it sit for a few minutes, then tried it with success.
It switches between models/receivers just fine after they are linked...but when you are linking to different receivers, its acts like it needs a little break in between :)
Glad you got your's going.
Infinite 12th 05-24-2012 07:23 PM
Thanks dude, there's nothing worse than something brand new not working :deathstar...lol
Look forward to some 12th testing and chassis setup situatio'n
ffejrxx 03-25-2014 10:01 AM
bump:
i had 1 r2106gf reciever that did not want to sync with a 3pl controller til the controller was sitting on the reciver
1ft was too far away i guess
it would blink red after trying to sync it
