Crc Carpet Knife Setup
Looking for some help with my setup.
Put on an old school front setup, shimmed the front block at about 2mm but front end still sitting about 6mm of ground clearance in front, my tires are new and I dont own a truer, also are the springs on the old school front end to go above steering block or below, below would seem to lower the chassis, but looking at it i dont see then how the suspension would work. Any help would be apprciated.
CRC
TTT
You need to true 12th front tires. Out of the packet I cut down to 45mm. Someone at your local track should have a truer.
THANKS
THANKS FOR THE HELP, FATDOGGY..... I WILL ASK AROUND AT MY LOCAL TRACK FOR SOME TIRE WORK....
Or just get longer screws and keep shimming..... For every 2mm you take off the tire you'll lose 1mm of ride height....
Originally Posted by mdwaeracer
I'm new to 1/12th and carpet knife. I bought one used and need help. Basically how do you set ride height,droop and how to set shock?
http://markpayneblog.blogspot.com/20...g-and-pod.html
