Team Titan ARC R10 190mm EP Touring Car >
Like Tree5Likes
Old 02-25-2014, 05:37 PM
  #961
vadersing's Avatar
Default NIB parts selling below cost
Need to clear out my entire collection of ARC R10 NIB spares ASAP.
Essential parts like Flex Motor Mount, Alu Suspension Mounts, DCJs, Alu Turnbukles, Gear Diffs, Low Friction Belts etc.
Total cost = Over USD 700 (retail price)
Special package price = USD 500
Will only sell as a package. Please PM your email address ONLY if you are interested to buy the ENTIRE PACKAGE, and I will send you the detailed parts list.
vadersing is offline
Old 02-25-2014, 08:41 PM
  #962
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Dang, you must have a lot of stuff.
Josh-n-ya is offline
Old 02-26-2014, 08:22 PM
  #963
DancewithMedusa's Avatar
Hi all,
I have an ARC R10 2013, all built and Ive run it a couple of times but I noticed the other day that my sway bars arent even. My other car doesn't have them so im unsure how to adjust them so that they're even, as in, if I lift the right rear the left will match, but when I lift the left the right doesnt even move.
Help would be much appreciated.
Thanks in advance from a noob
DancewithMedusa is offline
Old 02-26-2014, 11:40 PM
  #964
sosidge's Avatar
Originally Posted by DancewithMedusa
Hi all,
Adjust the length of the drop links until the bar acts evenly on each side.
sosidge is offline
Old 03-01-2014, 12:53 PM
  #965
Default Urgent help required
Guys i need your help. As u know the arc has a 3 degree toe in block in the rear. I was setting up my car on the gig and noticed that the left side is 3 degree exactly but the right is 4 degree.
I tried everything but i cannot match them. I ve checked droop, suspensions, tweak, hinge pins but simply cannot match
I have the 2mm chasis
Can u please help me out and advise what can it be
Teamcastagna is offline
Old 03-01-2014, 02:04 PM
  #966
Uneven rear toe is an issue on quite a few cars, best ignored. But if its really bugging you, then you could try loosening the blocks, then apply right pressure to the front block and left pressure to the rear block as you tighten them.
cyclonetog is offline
Old 03-01-2014, 02:20 PM
  #967
Josh-n-ya's Avatar
Question? Are you using the split blocks as you front rear suspension holders? If so I had an issue with that as well. One side 3* and other 2.75*. I went to the solid front 0* suspension holder and my problem was solved. Was going to get another set of split blocks to see if my first set was milled wrong. Not a real big issue but noticed my tracking was off in the straight a hair.
Old 03-01-2014, 09:27 PM
  #968
In fact i am using the solid 0degree holder. So do you suggest that i ignore or else try new block ?
Old 03-01-2014, 10:57 PM
  #969
Trader Rating: 15 (100%+)
Id start in two areas, Make sure hinge pins are straight. If the pins are straight, swap the rear upright assembles from left to right to see if the readings change to confirm a warped upright.
trigger is offline
Old 03-01-2014, 11:48 PM
  #970
Thanks for your reply, can you please advise which part is the upright?
Old 03-01-2014, 11:50 PM
  #971
Rear hub.
-Mike
grippgoat is offline
Old 03-01-2014, 11:52 PM
  #972
The rear uprights are also called the rear hubs(where the axle bearings sit in).
trigger is offline
Old 03-02-2014, 06:23 PM
  #973
Professor's Avatar
Default part #'s
just trying to get my head around thease part #'s & which part it is,can someone help me out here,these are the 3 length steering arm lengths but i dont know which is the 18 , 20 or 22
pt# R102821
R102822
R102823
any help is much appreciated
Professor is offline
Old 03-02-2014, 07:53 PM
  #974
http://www.arc-rc.com.tw/products_r10_2013_option.html
trigger is offline
Old 03-02-2014, 09:29 PM
  #975
Brokin Racing's Avatar
Trader Rating: 74 (100%+)
pt# R102821
R102822
R102823
Graham, go thru A Main & get the 20mm ones...that's my thought
Brokin Racing is offline
