View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
That thread is hilarious Myron.
you need to show up to give a whoopn
guess ill just do that and hit Cleveland in the fall...
Ok I am putting together a vta running a 2015 t4 what gearing is everybody ranging from for a track of about 115 straight also is there a spec motor or it's what ever roar approved 12.3 25.5t motor
Spec 25.5 Motors
3.6 is a good start, with 40 deg time
Damn so the trackstar v2 isn't on the list well that sucks was hoping to use that till I get a motor hopefully the club will let it slide for a bit
New Tires!
My protoform tires come this week
I sure want to see if the new tires are the same as the old tires as far as traction. If they are better, then I'm throwing out my old ones. If they are worse, then I'll hoard the old ones until they are worn to the nubs. Best case scenario is they are exactly the same.
my testing says they are very close to the same once broke-in...good news is our track has the most ridiculas traction most have ever seen...and Im not gluing the sidewalls like the HPI....5 races and lots of practice and no glue...great work PF
no carpet tracks in Arizona.....so, gluing takes away traction?
Our testing has shown they are right on pace with HPI. No sidewall glue needed on black carpet as Myron said, which is a plus. On asphalt, they may take a few runs to break in but just keep applying additive (thinner additives like mighty gripper, SXT 3.0 etc work best) and grip will start to come up.
They do need to be glued for asphalt racing right?
