Drift Tires
Drift Tires
anybody how many brands make drift tires? has anybody tested them? im thinkin of getting some and wehre can i get them?
home depot. pvc works best for me. yokomo makes a few types. hpi i think came out with sum. but yea. pvc. abs. tape. works
i wrapped an old set of foams with electrical tape. they work well.
just make sure you pull it tight as you wrap it and that the end of the tape lays correctly so it doesn't peel off. 3 exact wraps(balance) you will wrap 2 in 1 direction and 2 in the opposite direction.
I use ABS, its the best working and most realistic thing you can use. I use to sell wheels with abs mounted on them but nobody wanted to buy them from me for what the wheels where even worth. If you are interested i could make you a set
i have run electric tape and abs/pvc. tape is ok but i gota buy alot of them constantly, mine wore out really fast. ABS/PVC has no grip wat so ever, and all u do is slide. i think thats really oring. wheres the fun in no speed wat so ever. teh reason i want drift tires is because i want grip and i want drift. i want to be able to drift but still have a little bit of grip for normal running.
with the abs on asphalt i can pull 25mph+ drifts, you just have to learn how to control the car and build up speed. I tried the yokomo drift rings and i personally dont like it, but give them a shot it might be what you want.
il see. il get some drift rings and ilg et some tires. i wil post a reply on how much they differ.
??? Enlighten me. I'm assuming drift tires are a training thing, teaching you how to run a racing line and not rely solely on your tires to corner. Excuse my ignorance...
i find drift as being able to slide a car sideways at a pretty fast speed.
i believe pvc/abs is for training. drift tires are harder ro mkae the car drift becaus they actually have some traction, as where abs/pvc doesnt at all. I believe thta pvc/abs drifting is too easy. all u do is steer and voila, imsta drift. dats to boring. as where if u need to brake the car and give it power o mkae the car understeer, now dats drifting.
Oh, OK, so it's more for real racing. Makes the driving style less like open-wheel racing and more like rally or GT, I guess.
Its more of showmanship and artistry.
ive been driftin for about 4 years now, i know my stuff. i personally dont like pvc because its just pure slidin. IMO tape feels better to me then pvc. i dont want to argue, im just putting down wat i believe.
also with drift tires, IMO the car can actually go straight and catch speed faster then pvc will ever. im running a novak ss5800 and i want to use it to its full potential. pvc for is just plain boring.
