Rubber tires for dummies
#361
Regional Moderator
Alright guys here's the situation.
Small carpet track.
Paragon GFX & Jack the Gripper are the only sauces allowed.
Most guys are running Paragon for both Rubber and Foam.
Recently some of us have decided to travel to an event where Jack is the Spec sauce. Therefore we have been running only Jack in order to get ready for the upcoming race.
The problem is we are getting a buildup of crud on the rubber tires when using Jack. This does not happen with Paragon. This happens with or without warmers. Basically for me, my car is great for about two minutes and then as if someone flipped a switch the car gets way loose off-power or at neutral power. Upon inspection the tires are covered in crud.
The carpet is fairly new. However, due to the small size of the track the grip is actually quite high.
Anybody else experienced this or something like it? Any suggestions?
Help!
Small carpet track.
Help!
#362
How are you guys cleaning your tires between races? How long are you saucing them?
#363
Small carpet track.
Help!
Small carpet track.
Help!
Steve
#364
Yeah I'd think it has something to do with mixing the sauces.. I could be wrong, but when I use jack at a jack only track I don't have this problem.
#366
Regional Moderator
Wow, thanks for the quick responses fellas. You guys are confirming exactly what I suspected might be the problem. I guess we will go the route of just practicing on Paragon and make the switch at the destination. From what I can tell there will only be a slight difference between the two (when the crud build-up is out of the equation).
#367
#368
Regional Moderator
You will need to set up your car for more overall and rear end grip at the Jack only track. Run the Paragon at home but have a plan as to what to change in your setup when you go to the Jack Only track. We changes a year ago to Jack only at out caprpet track (Minnreg) and it was a big diffrence at first. Then we figured out what to change (use a spool, softer springs/oil, increase camber gain in the rear, etc...) and we were all good.
By the way Adrian, I got the new RR on the track for couple packs this past weekend and it was sooooooo good! New track record courtesy of BMI.
#372
Having read the forum and getting a lot of good information I am a bit closer to understanding rubber tires. However I still have questions. RC Riot (new on-road track) expanding the racing here in Albuquerque from carpet indoor to asphalt outdoor. The track surface is new and very green. The current plan for track seasoning we are going to mix 1/2 gal VTX and 10 gal sugar water and spray it 45 minutes before practice. For those that don't know Albuquerque is hot in the summer so I am a bit worried. The outdoor track is going to have nitro 1/8,1/10tc as well as 1/10tc stock and mod on rubber tires. We will also have drifters but I don't think they will effect the grip level. So how are the foam nitro classes going to effect the electric rubber classes? Also what rubber compounds/ inserts (still lost on compound ratings) should I carry at the track? One last thing now that it should effect rubber vs foam but the track in on a 11 deg slope to it. This should make it harder to setup, however, I would not think it would change the compound for rubber. Maybe it would change the insert needed? Any help would be wonderful so I can order tires for the track store.
Jeff
Jeff
#373
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
-rocky b
#374
Revision to that last post...carpet is on order so we will be going straight to the rug, and that leads to my question: What tire do you recommend on brand new fasttrack HD? This is for SS touring (13.5) with Jack as the spec sauce. The only experience I have is asphalt parking lot, and my setup works well on CS-27's and RP-30's. Thanks!
-rocky b
-rocky b
#375
Bumping an old thread....
I was going through some old boxes and came across some old wheels and tires still sealed. I have 3 sets (of 4) and wondered if they are still worth something. They are older, but I wondered if they might work for carpet, or are these better suited for pavement?
Yokomo p#: ZR-138G2 Beltec 5G 24-48-8 Slick tire.
According to Yokomo, they are still offered, but not much info. What inserts should I use and what are these good for??
MOmo
MOmo
