Sy Brand FS104WW
Sy Brand FS104WW
Here you have some photos of FS104WW conversion car. I think this one has F103 rear differential and F103 dimensions to use F103 type tires using special front uprights. Please confirm if someone knows...or understands japanese!!!.
The conversion is for F104 wheels.
http://www.centralrc.co.jp/new_centr...i_fs104ww.html
The F103 and F104 diff is the same width.
The reason they are showing the right side wheel is they are trying to sell a new way to mount the wheels so you can adjust the diff from the outside without taking off the wheel, This is why they are showing F103 wheels on the rear. Its can be confusing,
They are showing two different products on the same chassis.
Thanks a lot for the information Bakaguyjean.
I have ordered one conversion kit from Japan (Banzai hobby webshop) for my X1.
So.. I will have to continue using F104 tires..
Regards
Regards
So where is the front springs? Does it work on the o-ring compression instead of a spring?
Yes, thatīs it. no springs at all. well, you use one from the two that goes inside the front horizontal damper and controls both wheels. Nice idea and seems to work very well...
Hello, looking at Scythe FS104WW web I have seen photos with Lotus 79 body (200 mm F104W/F103 size) and a new kind of rims for front and rear tires. The new front rims include 5x8 mm ball bearings.
http://www.sy-brand.com/new1038.html
http://www.sy-brand.com/new1016.html (At Bottom of the page)
Does it mean a fast and easy way to use F103 tires for the conversion and use of f103 bodies?
Regards
Regards
anyone know
how can i purchase one of these conversation kits?
well
thank you very much
Hi guys
Is anyone still using this kit i've just built one up can't wait to get it on the track
