Are pros using the Hudy Set Up Station?
Gravity RC
Camber can be adjusted pretty easily without a station. The benefit of a station is that you can adjust toe- in with some accuracy plus adjust the toe-in as you adjust front camber.
Trader Rating: 102 (100%+)
PROs
i think the better question would be are most people using the HUDY station
remember most Pro (sponsored drivers) will have some sort of deal. So they may opt to use what is cheaper for the pocket or what is mandated to be used.
I will say most of the tracks i visited HUDY seems to be most utilized setup station.
by far the easiest to see when reading the numbers.
and the quality is by far the best.
just my 2cents of course.
it's almost the weekend i am getting my stuff ready.
I got rid of my Integy station due to the slop in it. The variance was about +/-1.5 degrees on camber. Not too good.
The Hudy is machined much tighter and is very repeatable, something I could never get with the Integy. Yes it cost more but then so do good quality tools. You do get what you pay for here.
Ronald Volker (who takes the Yokomo designer/mechanic with him to races) has posted on this forum that he does not use the setup station. Just ride height gauge, camber gauge and a droop gauge.
I'm with him - what is the point of taking the wheels off a car to take measurements, when the car will always have the wheels on when you actually use it?
The only good way to do it this way is by using setup wheels. Then it kinda is the same thing as a setup station without the accuracy.
The camber and toe angles will be the same with or without wheels on the car. And if you are using used wheels/tires to set the car up, odds are very high that you will have a whele that is not perfectly true.
I found +/- 1.0 degree variance in camber with a brand new set of Solaris wheels, depending on where I measured on the wheel. Some of the other wheels in the set were better, but 2 of them were off enough that I could not get repeatable trustworthy results without the setup station.
Because almost no wheels are straight. Try checking your camber with the wheels on, Then turn the spur gear a 1/4 turn and check again. Your camber will most likely change..
Agreed. Whether or not the actual values are off by a tiny bit, your reference points (in this case, your measurements) have to be consistent.
I remember one time at the track one of the locals came by and said that he doesn't need one of those things, he can do it by eyeing the wheel. When he brought his car over to show how good he is was when he got a shock. One wheel had 2° and the other three had between -2.5° to -6° all set by eyeing with a coke can and used wheels. His driving somehow improved after we set him up, imagine that!
