New Sakura XI
#301
Dose anyone out there know which Spec R diff fits into the XI?
#302
I find if you are simply running the gear diff in the rear, just a little bit of tamiya anti wear grease gives good resistance and no leak issue. I thought i have to go back and add grease very often to maintain the resistance level but it turned out to be not the case. I think maybe add thicker oil and less of it might also work.
#304
hi there, is there any hopsup for this xi, I'm looking for the almu knuckle n c-hub, pink anodized..
here my xi dh, plise write with w3 or http
photos-d.ak.fbcdn.net/hphotos-ak-prn1/67257_10200462445024569_728921834_n.jpg
#306
Diffs Not Level
Just started building an XI DH kit and I noticed that there seems to be a slight left to right diff height difference (diffs are not perfectly level). At first I thought I somehow mixed up the "A" and "B" eccentric bearing holders but it isn't possible to assemble them incorrectly. It's also very easy to see if they are installed at the same diff tension settings. I checked for flashing etc and but can't find a reason why the diffs are not perfectly level. The upper bulkhead covers/bearing caps also fit very tight (both left and right).
#307
Hey,
Ive got a XI with DH conversion kit and have some problems with it.
1. Problem with the Rear at accelerating out of the corner.
2. I need a bit more steering in Long, fast Corners
What can i do?
Tires Sorex 36, soon Ride 34 cause of Reglementation
Front:
*Toe +1°
*Camber 1,5°
*50wt Oil 3 Holes
*Tamiya Mini TRF Yellow Springs
*Medium Swaybar
*Solid axle
Rear:
*Toe 3°
*Camber 2,5°
*50wt Oil 3 Holes
* Light Sway Bar
*Gear Diff Oil ??
Pic: Blue is where i've got the Accelerating Problem
Green is where i need some more steering
Greetings
What can i do?
Front:
*Toe +1°
*Camber 1,5°
*50wt Oil 3 Holes
*Medium Swaybar
*Solid axle
Rear:
*Toe 3°
*Camber 2,5°
*50wt Oil 3 Holes
* Light Sway Bar
*Gear Diff Oil ??
Greetings
#308
David have you made sure the locating pins on the underside of the bulkheads are seated properly in the chassis and not miss aligned to make it uneven
#309
Can anyone confirm that their Sak does not have this issue? Look at the space between the outdrives and the upper bulkhead camber link "wings".
#310
Registered User
@brinni, witch class do u drive, stock (17.5, 13.5) or modified. the setup between stock and modified ist very different for the sakura.
#311
@gpmp
Stock, 17,5T
Stock, 17,5T
#312
Hey,
What can i do?
Front:
*Toe +1°
*Camber 1,5°
*50wt Oil 3 Holes
*Medium Swaybar
*Solid axle
Rear:
*Toe 3°
*Camber 2,5°
*50wt Oil 3 Holes
* Light Sway Bar
*Gear Diff Oil ??
Greetings
What can i do?
Front:
*Toe +1°
*Camber 1,5°
*50wt Oil 3 Holes
*Medium Swaybar
*Solid axle
Rear:
*Toe 3°
*Camber 2,5°
*50wt Oil 3 Holes
* Light Sway Bar
*Gear Diff Oil ??
Greetings
#313
I think I will disassemble everything to make sure but the bulkheads seemed to fit perfectly and the locating pins looked flush with the bottom of the chassis. Both front and rear diffs are not level - you can spot the difference easily by viewing the space between the upper bulkheads camber link wings and diff outdrives. On the front diff one outdrive comes within a hair of contacting the upper bulkhead (underneath the camber link mounting location) I will try to post a pic or 2 when I reassemble everything.
#314
I will find the reason tonight.
#315
