Old 07-19-2011, 06:36 PM   #1
MotoRider42HC's Avatar
Questions?? Need Help Getting Started In 1/10th Indoor On-Road
Hey All,
I used to race a Slash 4x4, back in 2010, got bored, and sold it all off...
The only thing left is my Li-Po charger, and now I'm looking at on-road stuff for the winter...
A friend suggested an X-Ray T3R, but I have no idea what kind of motor/esc to pick, servo, etc...
Are there any other kits, rolling chassis, or RTR setups out there that would be better to start off with?
I kinda have a limited budget, and I don't want to have to buy a RedCat, so, if someone can help me budget out a decent setup, that would be AWESOME!!!
Thanks!
- James
> Sponsored By: http://xtremercracing.blogspot.com/
>> Motocross, Real Car & R/C Car Enthusiast
MotoRider42HC is offline   Reply With Quote
Old 07-19-2011, 06:50 PM   #2
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
to be honest, your best bet is to go to the local track and see what those guys are running... there are quite a few different classes to race in. Also, it helps to see what the other guys are running because if you have the same chassis, you can borrow/swap parts when stuff breaks. Our club has a mix of every car you could think of.... the most widely used at the current moment is the TOP Photon though. They are still expensive (about $360) but they are extremely competative. Most tracks i've visited run a 17.5 stock motor (I like the Team Epic Duo 3 because it's one of the best and it doesn't use a plastic end). The ESC is usually a Tekin RS (that's what most are using at my LHS) or an LRP. A 2S lipo will be what you need and your club will most likely tell you which tires you need to run to be competitive.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 07-19-2011, 06:53 PM   #3
ohh i forgot.. most of the time you can find a couple guys willing to part ways with one of their vehicles cheaper at the club/track than on this forum.
Fishhook
Old 07-19-2011, 07:18 PM   #4
Cool
Thanks for the insight!
I have a question about that 17.5, because I was aware that brushless motors are measured in kV...? Isn't "turns" a brushed motor measurement?
LOL, sorry if I sound stupid, but all the ppl I ran with off-road always talked about kV, motor size (380/540/550) and gearing...
The class is going to be a 1/10th with, "blue spec" tires??? I think... They also said something about that 17.5 thing, but, that brings us back to the previous sentence... LOL.
Is that $360 TOP Photon an RTR, or just a chassis?
THANKS!
- James
Old 07-19-2011, 07:29 PM   #5
the motor kV and the 17.5 are two different types of brushless motors. If the description says it's a 17.5 turn motor, then that means it is a sensored motor and requires a sensored speedo (sometimes they also list the kV rating too) but, if the kV rating is the only indication of the power of the motor then it is a sensorless motor. In off-road, sensorless motors are more common.
"Blue Spec" tires.. sounds like Jaco Blue Rubbers... I'm guessing.
The Photon is a kit and is not RTR...
Fishhook
Old 07-19-2011, 07:35 PM   #6
Talking
Whew! I am so glad someone finally explained that turns/kV thing.
Sensored motors are much more expensive, right?
So, if I have, say, a sensorless 3300kV motor, then would it be illegal to use it in a 17.5 class?
Thanks Again!!!
- James
Old 07-19-2011, 07:43 PM   #7
Sensored motors are not more expensive than sensorless... it all depends on the manufacturer too. If you are in a 17.5 class, you really can't run the 3300kV... that's closer to a 13.5. A 2300 or somewhere around there would be equivalent.. and they may be lenient and let you run it for a short time... but since they are pretty much the same price... I'd just get this https://www.ssl-stormerhobbies.com/c...=cs&pn=TEP1053
Fishhook
Old 07-19-2011, 07:45 PM   #8
Exclamation
Also, what kind of servo do I need?
A metal-gear high-speed,... I guess?
Thanks!!!
- James
Old 07-19-2011, 07:58 PM   #9
There are two servos that you should take into consideration
Futaba S9551 and Savox SC-1251MG
Fishhook
Old 07-20-2011, 06:07 AM   #10
tc3team's Avatar
[quote=ewashburnaf;9412451]to be honest, your best bet is to go to the local track and see what those guys are running... quote]
+1.
See how your local racing programme operates and what cars are used, and how friendly the club is. If you are made to feel welcome it's a good indicator of the people you will be racing with.
Watching a few races will show you what speed you can expect to race at and learn the track a little.
I have used a Futaba 9550 for at least 3 seasons now and had no issues, they appear to be a very solid, low profile servo
A 30C lipo should be good enough for 17.5, (make sure it is hard cased and 2C) find out where to get the spec tyres from, pick up a good deal on equipment and get racing
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Tags
indoor, kit, on-road, rtr, setup
