Reedy Sonic
#317
Gearing
Oh, Ok. Thank you so much.
I am new in this stuff, still learning.
I will take a look at my manual book.
Thanks.
Thanks.
#319
Gearing
Thanks, I know my internal ratio gearing for my Tamiya TA05 V2 is 2.055.
I will try to change the spur gear to 90T let see what is the speed and the temp.
#321
so i will be ordering a reedy sonic 17.5 in a couple days ive been running tekin for awhile now and my dad just got one of these motors and i like it a lot so im gonna get one now so my question is, how do these motors accept timing? like do they do well with a lot of timing added or do they work better with less timing? i already know about temps and gearing and all that so this is my only question about it. thanks
#322
#323
I burned my 5.0 Reedy. Since they don't sell the stator separately I would like to know if the Thunder Power stator from a ZR3 S would fit?
Thanks for any info!
#324
I would like to know if the rotor that comes with the 17.5 has the most torque? Or is there one that has more???? Looking for more torque.
#325
As far as ROAR legal rotors for stock, it comes with the biggest rotor (most torque). If you dont care about ROAR legality, you can run a mod rotor for more torque.
#326
I bought one hardly used 7.5t today (after getting the possibility to test it) and I am absolutly fascinated of the low running temperatures this motor has in comparison to my X12 7.5t. It was at least 10-20°C cooler (same setup) and I it lasted 14 minutes on a large outdoor track until my 5500 Reedy battery gave up.
Our clubraces are always 15 minutes and I was totally surprised that I nearly made it while driving as hard as I could and having better laptimes than the 9.5t setup. I love it!
#328
Supposedly but mine didn't. Mine measured 12.4 X 24.5. Bought the largest legal replacement, it measures 12.51 x 25.2. There seems to be quite a lot of variance in manufacturing.
#329
what is a good esc to run with a 8.5t reedy i can get the sxx with reedy combo for $235 from amain but i would prefer a budget esc that works just as smooth with all the adjustments the sxx has
