Mi2 v.s TRF415 v.s RDX
#62
vi3tishduy:
You can parts direct at www.racing-cars.com/usa. or visit the various sponsors on this board (SpeedtechRc, KTHobbies)
I run the Mi2 stock outdoors except for the following items:
- Gear Adaptor so you can handle standard gears
- Pdubracing bumper to replace the standard one so that you will save your arms.
- if you race stock and 19T, the stock plastic bones work fine, to run modified you will need the steel fronts and Ti rears
To run indoors, I have all of the above with the addition of:
- Short front and Rear shock towers
- alloy rear hubs ( for better adjustment)
- I have not tried the stiff chassis but I don't believe that I need it for stock and 19T
The current shocks are a pain to build compared to the Tamiya, but you should not need frequent rebuilds and like all things, you can get the hang of them after a few times and its a non-issue.
You have the option of diff, one-way and spool for the Mi2. The diff is standard and all that I use.
The only other item I intent to purchase are the spaces for the rear for
Thats about it.
If you plan to run at the club/local/metro area then there is little that you need.
Thats about it.
#64
ah, no one has answerd my question yet, some one said something about schumacher coming up with a new version of the Mi2 with new shocks or something? is that true? and when?
#65
Since the Mi2 is still fairly new, I doubt they will be coming out with a new version soon. Maybe new chasis versions, but a new car is doubtful. My speculation. They've just come out with spool, etc., so the Mi2 is new.
#66
no they are not comming out with a new version. My understanding from my contacts within are that there is a plan for revised shocks. Not for reasons of performance thus for ease of assembly and easy maintanence!
#67
A properly set up 415 is a beautiful car to drive, borrowed a friends for a couple of races and was straight on the pace after a lap!
It is so easy to control at 110% and very quick in a straight line
Xrays I find are a bit taily flat strap and have never driven a Schummacher so can't comment on that
#68
i beleve the xray cars are the best out there ......................just my oppinion but my friend has a fully dun up shumi mission and his shocks are the worst desighn to work on ive ever seen but they are smooth onece you get it right
#69
I've come to a decision.... Either the Mi2 or the TRF415.... Mi2 I can get a good deal for it from a friend but, I dont know if the quality of the car matches the TRF so I still dont know, any more comments on these cars?
#70
I ran a 415 last winter and bought a Mi2 to run this winter. As far as quality, both are great. The Mi2 is alot easier to build because Schumacher packages the parts in seperate bags by assembly steps. With the 415 you pretty much have to open all the bags and search for the correct part/screw. I won't have a chance to run the Mi2 until this weekend - so I can't comment on performace, but the support from the guys at Schumacher (Adrian and Paul) could not be better. If you have any setup questions just give them a call or post it on the Schumacher thread and you will have your answer very quickly. I am already sold on the car without having run it yet. Don't know if this was much help for you, but I just thought I would share my opinion.
#71
i've just recently ..... purchased the 415 ........
an out of the box........ was performing really well .....an the thing was my car was completly tweaked ...(that due to me building the shocks ...alittle wrong..not the car)..... so i can say the 415 is really good ......... stable an feels smooth with very good acceleration .....
i'd say both are as good as the driver is ............ since any top driver can make any car go fast ........
so i believe it come down to wat u like to see ....
#72
XRAY
#73
Registered User
RDX
i race with a tem corally driver every week he has had the RDX for 2 or 3 months now and it is much better than the assassin trust me it will be a superior car
#74
As the other Mi2 guys have said theres new shocks available sometime soon. There isnt anything that NEEDS to be changed on the Mi2 straight away. If u r an experianced racer then u may not be totally happy with the standard shocks & may require the tamiya shocks or the new schuie's.
And anyway.... purple looks better than blue
#75
Hey all...Tamiya is going to release "another" sedan...the $415MS. Is that 3 cars already this year? Pics on www.rczone.net...
