Team Losi JRXS
Originally Posted by JRXS_chris
Brilliant stuff, I think I'll give it a go too, doesnt seem a difficult conversion to make.
Takes about 20 mins the hole thing, also remember that the Ben Rayments set-up uses the rear to front shock tower mod too
Cheers Malc THE CAN MAN
losi has posted the new products for the jrxs on ther website http://www.teamlosi.com/newprod/index.htm I got to get some of the new spool pads
Geez... those spools do look the goods.... I've been using these as spool pads with great success:
http://www2.towerhobbies.com/cgi-bin...?&I=LXC590&P=7
Just drilled a 5mm hole for the bearing....
But I'm gona have to get a set of them .
Dremel parts!!!!!! Nice touch my Brutha!!!!!
Brant
Brant
Brant
J/k
What's all this inside joke stuff about a dremel?
Do you have to dremel on the JRX-S of yours POOKTY? You know what I say to that....
I dont know why so many people make fun of dremeling this car... i have had to dremel every car I have owned at one time or another.
TC3= center brace- to move cells closer to center
FK= rear arms, to accomodate foams- chassis slots
XXXS= had to make the shock bodies shorter in the V1 kits..
RDX=.. chassis slots, and rear shock tower added support for camber links
LOL
The wholel Dremel thing is from all of those BK/PK brackets I made. Every set I made was by hand and with my Dremel. When it started I never thought I would end up making as many sets as I did. So, the Dremel has many hours of bracket time on her now. Thats how it started.
Brant
hey there, iam currently running the tc4 and was thinking about the jrx-s
would this be a wise choice? just try sumthing differnt, what are there strenght, and parts back up like in aussie if anyone know's i run brushless mod class. cheers
I agree Keith, but that's why I like the T2 so much.
OK now we've had the new arms, JR link, rear shock tower mod, a number of front shock tower mods etc, what's everyone's current Carpert with Foams setup?
I'm back from Uni for a month or so and probably going to be going some racing, carpet tracks with foams (normally no additives) but I'd say medium-traction.
Many thanks
Oli
Many thanks
Oli
Over to Keith...
Has anyone tried the 48 pitch gearz they offer for the jrx-s. I onlyask because i mainly race off road and was hoping to only carry one style of pinions. if so any recommended sizes for stock , 19t and a 10x2 mod. I assume its similar iin gearing to my xxx-4 but a little different due to tire size. i race on asphalt with stock tires right now. Yokomo yellow precision discs on the way. I read a lot of postings and have seen nothing on switching to the 48 pitch gears. Is it a bad idea? I will run the 64 if that is what is most effeicient and easiest to tune. any help would be greatly appreciated for a dirt convert. thanks in advance
Many thanks
Oli
Many thanks
Oli
RCknight.. there is a carbon fiber version of the XXXS.. its called a 415 or T2. JOKE... but really, i think the JRXS is superior to the XXXS. For a long time I was on the fence and felt the same way... but now that I got to know this car, i am going much faster that i did with the XXXS.
Keith
Yea...but....
Im pretty content with my setup.. I havnt seen the need to get away from it aside from going to a 25LB spring.. and the JR link. You can view my setup on PG 351.
Keith
Keith
