Team Losi JRXS
#8657
Originally Posted by TCR
So cal raceway in Hunington beach CA. has them in stock
I have yet to see a part number for the for the item thats going to be out in two weeks. If the shops don't have part #'s they can't order them.
Maybe the part # will be out in two weeks =)
I have looked on here and I haven't seen anyone talk about a set up for carpet but Maybe I missed it in the 289 pages LOL
or Maybe the arpet set up will be out in 2 weeks LOL Sorry couldn't help meself
#8658
Well you just missed the setup for foams on carpet ti is in rob phillips signature on page 288 it says paul c.
#8660
Originally Posted by WD40
I'm sure other JRX-S owners have noticed the problem with the wobbling spur gear. Is there a fix that I can do (BESIDES THE SPUR GEAR ADAPTER) that will keep the spur gear from wobbling?
Brant
#8662
R/C Tech Elite Member
Does the PRS spur gear adapter add much weight? Does anyone know the part number by any chance?
#8665
I have that infamouse speed woble... i had added some teflon shims to compensate for the problem.
the PRS adapter is nice but i like the losi gears very cheap $$$
#8666
#8668
On the spur gear wobble
I have found that if you ease (with a file or sandpaper) the sharpe edge of the shaft before you press on the gear it will be straighter. The shaft will sometimes broach (cut on the inside hole) the gear, causing it to wobble.
Ron
Ron
#8669
Originally Posted by losi_g+
Brant
#8670
Originally Posted by POOKYT
I just checked it and all is well!
Brant
Brant
Brant
