Team Losi JRXS
#7711
Many thanks.
#7712
Originally Posted by Fatboy Joe
Hi, how does your car handle with the front top deck modified to fit in the MM Cooler? I am assuming there will be more flex up front due to the modification. Let me know, thanks
Sonny
Sonny
Anyway, I will be testing both sets of conditions today and will post results tonight. My only concern was if the car sustained a heavy collision (front on) it might break the modified top deck. Time will only tell.
#7713
Originally Posted by JRX-S Bill
Mud,
As Andrew says, flip those rear blocks.
For what track surface temp range are you using Takeoff CS-32s for?
I usually jump from Takeoff CS-27s to Sorex 36s for mid-to-high temp conditions (say below/above 115F±) on asphalt.
In my mind, CS-32s have a limited temp range.
#7714
How do JRXS's run indoor with rubber tires on carpet?
#7715
Originally Posted by BlackKat
YO BILL,
My dad and I haven't given up on the JRX-S yet despite the fact he is ready to dump it after driving my (now his) TC4 and loved it. I'm going to ask him to machine us some BK brackets to try on the Losi before we get rid of it (if we do)
Just curious...I hear the BK brackets transform the car into something else & I hear the Numan setup works well on carpet-rubber. How close is it at HW Gilroy? Any "must change" settings for the rug? The stock out-of-the-box setup felt okay (a little skate-y) but was badly off-pace. The Hodge Stockton setup felt weird...loose on-power and not much better off.
TV
#7716
Sonny
Sonny
As I said in another post, I felt that the chassis had a little more lateral flex in it, but front to back rigidity is the same. My main concern was whether or not it could handle the stress under racing conditions (chassis flex and crashing) - so far so good.
Main thing is that it seems to work without affecting the handling of the car and I can now run the MMR motor cooler along with a motor heatsink in the car!!!
#7717
#7718
Hi Todd
Is there any reason Losi decided to keep all the shock springs Black rather than use colors as a differentiator?
#7720
Todd - Congrats on the win! Just wondering, you wrote 5mm of droop, do you measure your droop from above ride height, or do measure from the bottom of chassis to the outer hinge pin?
Also any updates on the new arms? ....think they'll be out by the nats?
Thanks.
Thanks.
#7721
#7722
That reminds me.... Does anyone know the proper dimension between the Captured Ball Ends, #A4253,in the sway bar kit? Thanks
#7723
Brant
#7724
A3-It came down to this for the overall win. It was either Barry or me that could win it all. We took off and Barry had a 10 ft lead on me until I decided to make some donuts in the back straight. I would fall back to 4th and I thought my hopes of winning were diminished. I would eventually pass 2nd and 3rd to get within twenty feet of Barry. Then Barry decided to crash into lapped traffic, which was then directly sent into me. We still we about twenty feet about with 45 seconds to go. I was able to reel Barry and we had a race to the line. In the last turn on the last lap we went into the turn side by side. I would pull the entire throttle that my Orion V2 7x1 had and would end up winning A3 by .052 of a second. The place went nuts with all the awesome racing that we displayed.
Was anyone recording the race
