Team Losi JRXS
#6722
haagundt leitzner
Originally Posted by rayhuang
Well-this is what you get when your track is down for two weeks......
looks good ray. with that big blue power wire, it's very patriotic.
#6723
LOSA4253
How many cups are included with the sway bar plastics?
#6724
Originally Posted by seaball
... and counting.
I was thinking along those lines too. If I rewire my speedo soon-I'll go with all red wires. of course youll have to give me a minute so I can resolder my motor
#6727
Originally Posted by Randy Caster
Looks good Ray, when you get that BK Brackets carpet setup perfected you gotta post it up, I wont have any practice on carpet before the intl. champs in September.
#6728
Last pic
Last one-I promise. Pookyt's bk bars installed. Tons of clearance on Parma Foam tires. The 20 lb springs feel a lot stiffer than the front 50 lb springs now. Kind f reminds me of a TC3 now where the rear wheel rate feels a lot stiffer then the front. I might need 15 to 18 lb srpings with them on...or maybe a 60lb front spring????? I dont know.
OH-and yes-they will be dykem'd red soon too.... Kind of missed them.
#6730
R/C Tech Elite Member
Sadly-I am not too confident anymore that I can dial in a set-up But I'll do my best. I will be running the car into the carpet this weekend and hope to have the BK bracket thingie worked out. It sounds good in theory. I just wish we could fit them on the front somehow.
Do you have a good baseline setup without the brackets?
#6732
Yeah-we all run Paul Ciccarellos set-up at the Gate. I am not sure if its on any websites-but thts the one. I'l look for it and pass it along to you. Another good starting spot is Paul Lemieux's Champs set-up. Its similar to Chicky's, but a lot lower front roll center and less antidive.
#6733
when you re-wire be sure to put a piece of black shrink-tube at the end of the negative "-" lead.. causes less confusion when your in a rush..
#6734
Originally Posted by karlo511
4
#6735
