Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc) >
Like Tree4Likes
Old 09-10-2011, 06:10 PM
  #346
KHoff7's Avatar
Originally Posted by geeunit1014
Hey guys, check this out, this is what ive been running the past few weeks on carpet/17.5 blinky, and its been working awesome for me. I did put in the new bladders for today with the same setup and it was very very good.
Maximum dialed, I have been running mostly the same setup and the car is awesome.
KHoff7 is offline
Old 09-11-2011, 07:07 PM
  #347
Default website
Is it just me or is the website down!
Little John is offline
Old 09-11-2011, 07:09 PM
  #348
cwoods34's Avatar
As of 10 seconds ago it worked for me.......
cwoods34 is offline
Old 09-11-2011, 07:12 PM
  #349
cwoods34's Avatar
And after I post that I discover it DOESN'T work for me.........
cwoods34 is offline
Old 09-11-2011, 07:19 PM
  #350
CristianTabush's Avatar
The Website is down
Godaddy, who is our current web host made some change on the server side and now our cart will not talk to the database. They claim nothing is wrong. BS.
They literally told me that it was "magic" that caused it. They said all things break and that our website just broke, just like when cars break down. Our site was not touched on our end and my a friend of mine, who is the greatest programmer alive that I know, said it is not possible. Some setting had to be changed on the server side. There is no way around it. He spent all day trying to make it work and it did not.
With that, we are already working on a new site, a hosted solution which is already up and functional, but not very populated yet.
By tonight, I'll have the RSD line up again. The domain will be different for the next couple of days while the server change propagates. In the meantime, you can stop by and see the progress at:
http://reflex-sd.3dcartstores.com/
If I am and continue to be MIA, is because I am on this in deep basement, no shower till I finish mode...
Sorry for any inconvenience this may cause.
CT
CristianTabush is offline
Old 09-11-2011, 07:30 PM
  #351
Thanks it makes me want to buy stuff from reflex even more when we have a person like you around who cares about his costumers. but about the site
Old 09-12-2011, 04:42 PM
  #352
shoe's Avatar
Originally Posted by Buckaroo
Got my bladders in the mail today, and used that as an excuse to crack open my shocks and install the new bladders and the 1,1,1.5 pistons that I've had laying around. WOW, buttery smooth and zero rebound with a 1mm hole drilled in the shock cap. Can't wait to get this thing back on the track and see how it handles.
Do you have a picture of the 1mm hole.
shoe is offline
Old 09-12-2011, 04:58 PM
  #353
Buckaroo's Avatar
I have a new camera coming tomorrow, I'll try to get a good picture of the top, bottom, and with the drill bit going through.
Buckaroo is offline
Old 09-12-2011, 05:05 PM
  #354
shoe's Avatar
Originally Posted by CristianTabush
Tom, below is our "standard" set-up for our track. It is a shorter track, but it runs big and has pretty high grip. I have handed down this set-up to all the TC6 owners at the track and they all have improved by at least a lap on their 6 minute runs:
Front:
-1,1,1.5 Piston 550cst oil
-15.5lb spring
-Outside link on tower caps (shorter) 3mm underneath the inside link, 2mm outside
-3A Roll center blocks
-4 Deg Caster
-Shocks 1 hole out on shock tower
-6 on droop
-5mm ride height
-Slipper Spool tight
-Black sway bar
Rear
-1,1,1.5 Piston 450cst oil
-13.5lb spring
-Outside link on tower caps 2mm underneath inside, 3mm outside
-shocks 2 holes out on shock tower
-4 on droop
-5.5 mm ride height
-Gear diff 700cst oil
-2.5 inboard toe 1 deg toe hub (if you are not running toe in hubs, 3 degs inboard is enough toe)
-Black sway bar
The set-up is super consistent and fast week in-week out. I like that I have not had to change it in a long time. To adjust your roll stiffness (i.e. if it leans to hard) you can remove shims from the inside camber link locations for minute adjustments. If it is not enough, I change my spring rate by 1lb before I change my shock angles (since changing angles affects damping as well as spring rate).
-5.5mm ride height
Can you put this in a Associated setup sheet. Thanks
shoe is offline
Old 09-13-2011, 10:27 AM
  #355
Mike, I will try to get that to you as soon as possible, but I am swamped wit the new site launch, since it had to be kind-of on-the-fly.
With that, the store is LIVE and Taking orders. All the RSD Products are available for purchase again.
Thanks for your patience and understanding guys!
Old 09-13-2011, 02:37 PM
  #356
Buckaroo's Avatar
Default TC6 Shock cap holes, 1mm
*** I just realized that these are pictures of a TC5 shock cap. Sorry about that, I'll get pictures of the TC6 caps shortly! (too many different cars on the bench at one time) ***
Buckaroo is offline
Old 09-14-2011, 07:08 PM
  #357
cneyedog's Avatar
Just did a rebuild of my TC6 shocks with the new bladders, and getting zero rebound is .... waaaaay easier, then with the stock kit bladders, got my reflex racing pistons and springs on there too ..... very smooth.
cneyedog is offline
Old 09-14-2011, 08:36 PM
  #358
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Here you go http://www.racerlog.com/w/images/9/94/CT_standard.pdf
CT will have to fill you in on the missing stuff, id guess camber is something like 1.5F/2R or 2/2 or something like that, front toe is probably .5 out, and wheelbase is probably the kit setting as well, but only he knows for sure
geeunit1014 is offline
Old 09-15-2011, 06:15 PM
  #359
Big Features's Avatar
Finally installed my RSD options on my TC6 shocks and I must say, I'm very impressed. I had no issue with the stock bladders, But these feel very nice indeed. I'm not sure when you would want zero rebound, unless there was ridiculous bite. I built mine with about 30% rebound, Looking forward to trying them this weekend.
Mike
Big Features is offline
Old 09-16-2011, 01:49 PM
  #360
Trader Rating: 27 (100%+)
Hi Cristian -
Are you shipping orders? I had an order processed on 9/11. No package yet
MDawson is offline
