Barracuda from Alex racing
#1426
Good
Originally posted by SpeedTech
As for parts, I apologize for the delay guys. What I'm frantically working on is a complete in depth articles on how to build the Barracuda R2 (actually, building cars in general) I'm trying to get this up tonight on www.alexracingusa.com so I can concentrate on the parts on Sunday and Monday (I have a huge box of parts sitting in my office at the moment)
So I apologize guys, please be patient
Steve Wang
Steve Wang
#1427
Originally posted by pkranger63
Did Dave ever post some carpet set-ups for the R2? I keep looking back through the posts and just can't seem to find it. Lots of info Only reason I ask is because I just placed my order for the R2 through speedtech and am gonna order some springs and such and was looking for a starting point.
Matt
Matt
Hi Matt
I'll see if I can Post a Starter Carpet set up with rubber Tires for you guys later tonight ..or if you have any other Question I'll be glad to answer them
-Dave
#1428
I really appriciate it, thank you. Also quick question. you said HPI springs are a direct replacement on the R2, are the springs I am looking for the SEDAN PRO LINEAR SHOCK SPRINGS 13x25mm or the 13x27mm or a set of each?
Thanks,
Matt
Thanks,
Matt
#1429
Thanks,
Matt
Thanks,
Matt
Use the 13x27mm ones I use nothing else..... but if you want the best overall Alex Racing Spring...then I would go for the 1.5/5.25
-Dave
#1430
I found what my problem was with the shocks, I was using the wrong o-rings in the wrong places DOH!
The manual shows the largest ones on the top end of the shock when they should go inside the adjustable collar, the first shock I built I also got the wrong o-ring on the bottom bit, I used the medium one which easily squidged out
Would be a good thing to add to your extra instructions Steve
#1431
-Dave
#1432
Nut drivers
Getting a order together for stuff for the R2...quick question..what size nut drivers are used to assembly??
Thanks again
Matt
Thanks again
Matt
#1433
I'm having more fun with the shocks, this time the usual problem of getting the plastic links on the bottom of the shaft Wish someone would start making them so that they were held on by a grub screw or something, coz trying to hold a shock shaft without it turning yet also without scratching it is next to impossible. I've found I had to pre thread the plastic ends with a suitale screw first but it's still difficult.
How far do they need to go on? ie. how much thread should be left showing on the shaft? if any
#1435
I have located a 4.5 and 5.5mm nut driver but no 5mm. Hmm isn't there a page with conversions for these sorts of things
Matt
Matt
#1436
#1437
Hermi'
Set the Front lenght to 60~61mm & the Rear to 63~64mm...
If you have needle nose plyers put some tape on them and grab the lowest portion of the shock shaft and then start to thread the plastic end on by a couple of threads then stick a thin metal bar like a screw driver or allen wrench though the plastic end to make it turn easy
-Dave
#1439
Originally posted by JDM_DOHC_SiR
Hermi'
-Dave
Hermi'
-Dave
Those shock lengths are different from the kit settings it says 59.5 and 60.5mm
