Barracuda from Alex racing
#646
Originally posted by fReShJiVe
regarding protecting the drivetrain from stones or anything that would enter the diff gear...what do u guys do as i see that for the front it's pretty well protected but not the rear.There are gaps between the plastic diff cover and the arms.
#647
Re: hiyas
Originally posted by dynoman007
looking for shock pistons for alex shocks ,,,, anyone have them we are trieing to run some carpet and with standard fluids cant seem to get the car stiff enough ...........tried to glue up one hole and even pin one hole it isnt working very well ....................
#648
Re: springs
what springs are most running i have been using yokomo springs . anyone have any other options with a nice selection ?
#649
wow
we are running foam tires enlarging the pistons would make my chassis drag horribly in the corners lol
#650
Originally posted by fai
I think the purpose of the two addition slots is to counter-balance the flex on the servo size... As you can see in R1, without the slots, the servo side will be more rigid than the battery side when the whole chasis 'twists'. I hope this improves car's performance a little bit... (I did add two slots last friday to my R1!!! Hope it workes!)
fReShJiVe: I found having the cover will 'keep' the stones inside instead of 'prevent' them from going in!! I have a bumper in front and it nearly blocks all stones coming in... For the rear, no cover at all!
I also see lots of people running yokomo springs: mainly pink and yellow. For me, I choose Atlas and Speedmind (HK)!! Fit very well!
Just placed an order about an hour for the C hub/servo saver arms/rear upright....should get it soon as i took EMS as shipping option....and they already billed my credit card for it hopefully to get it by Tuesday.....
By the way any suggestion on getting more ackerman angle on this car
#651
springs
how much for full set of kawada springs ??
#652
pistons
anyone have blank shock pistons ??? or options ???
#653
Re: springs
By the way the "Jet" products that i received has some problems so no pics yet.
1)C-Hub doesnt fit there's about 2.7mm needs to be shim anyone with "Square" c hub care to comment as the seem to be a copy of "Square"
2)servo saver arms had 2 of the right arm no left arm
Only thing that are really nice fit are the rear upright.Already called and email them and waiting for their answer
#654
Re: Re: springs
not sure though...maybe around $5 per pair
and as for the servo saver arms have 2 right ones???? Bad Ju'Ju'
But Jet should get back to you ASAP... they are prety good about that
-Dave
#655
JDM - i called them up yesterday regarding my problem and even send pics via email to them ....were told they would get back to me today...by 7pm no return mail again so i called overseas again ......so they told me they would be sending a new set of servo saver arms and spacers that they forgot to include with the c-hub.....optional c-hub need spacers....hopefully they will send it EMS as that's what i paid for...??? not sure if this is a case of wrong measurement or what but if stock doesnt need any shim why would an optional ones need...they could have just mold it like the stock ones so no shims needed.....i also need to send back the arms to them(extra cost on me but they told me to send the slowest and cheapest method so i suppose it wont be much)....i suppose this is what when guys say "u get what u pay for" ... i should have bought the Square ones instead.....i guess next time i will let others to buy new products first before trying them out but overall they are still okay to deal with as they did admit their mistake in packaging.....for the rear upright they are SWEET!!!
#656
attached is the picture of the c-hub with Square knuckles
#657
Wow
For me it comes down to quality I guess .....Also that space might be a good thing because if you ever get the Speedway PAL short arm conversion the extra space that the Jet hub provides would be good because with the kit you need to file a tad bit off the front of the A-arm were the knuckle hits at the bottom of the shock stroke...about 2mm but thats it no big deal
-Dave
#658
Re: Wow
Originally posted by JDM_DOHC_SiR
Wow thats one big gap????!!!!! I would get the Square ones next time..... but then again the Jet price can't be beat ..
-Dave
-Dave
#659
fReShJiVe: How about yours??
#660
fai- "JET" rear hubs fit nicely in mine...i'm also using the hardened arms
