Barracuda from Alex racing
#4951
@ cHckbOY5
i took a pic of every page of my instruction manual, u can finde the pics here: http://home.arcor.de/fabian.rc/xplo_instr/
hope this helps....
hope this helps....
#4952
thanks
#4953
Originally posted by Ko Racer
Dave pic's show us the pic's and do you know if they will offer it as a left or right side battery placement chassis?
-Dave
#4954
Regional Moderator
Originally posted by JDM_DOHC_SiR
Well I have pictures...but they reallly suck because my digi camera died...so I had to use my cell phone camera.. so I`ll post the pic`s in a bit but they are really small.....anyways ALEX will only make a standard chassis layout this time.. no upgrades like they did before..with the R1~r2...and the Batterys will be on the right side ONLY..!! not that it makes a differance the kit will be released on December this year..!!
-Dave
-Dave
#4955
-Dave
-Dave
didn't your digi cam die before too, sounds like you need to get it sorted
So they're not bothering with the half a dozen options, kinda good, but I thought they might move the cells atleast a couple mm forward, ahwell.
You said before the A-arms are slightly changed, beefier around the large pivot balls, will this be a change we can use on the R2? ie. they'l stop making the old ones since they're not needed.
#4956
Regional Moderator
Originally posted by Herminator
Any pics will be good
sounds to me from what im told the R2 will still be around maybe just a few new parts to play with
#4957
time will tell
#4958
1)IT's not going to be limmited it`s replacing the R2,R1 ect ect
2)THe 5mm spacers on the back of the bulkheads are now added on the the bulk head so there is no more tweek problems when you crash(longer and one peice)....also they incorporated a new swaybar mount into the bulkhead so you can change the stabilizer out without taking off the shock towers
3)New motor mount ..so you will nolonger need a drivesystem for the Car...this thing is trick!!! it looks like the Xenon and PAL mount where the Motor goes on(SD EVO ect ect) but it ties the upper deck and lower deck together mounts by 5 screws 4 on top and one on the lower chassis
4) Super Strong 100% pure Carbon fiber chassis not the 70% blend like 99% of the RC cars have today 20$ more rigid than the standard R2 chassis....also there is no visible weave to the carbon fiber and there is a Sweet looking Rainbow glitter now in the chassis( nice Eye candy)
5) New wiper style steering rack (think TC-3) but better...much more adjustable Ackerman(better idea in my book)
6) Drive shaft is now a dogbone type(just like the PAL Drive system) but the shaft will still be carbon and also you will be able to run a Drive shaft oneway along with the front oneway later too(even more cornering speed)
7) Chassis balance... they have moved the battery forward 3mm and the motor mount is back 1.5mm (just when you thought htat the R2 had good chassis balance they ,ake it better )
8) Colors..they will be the same
Red
Blue
Pink
Purple
9) Same Retail Price 39800 Yen...so you can exspect to but the new R3 for the same price as the R2...but you will have much more options that come with the car
10) 85% of the R2/R1 parts will work on this car bevel gears diffs shocks knuckles hubs ect ect.. (basicaly drive train and chassis have been changed for the better)
11)Slightly more beefier front and rear a-arms arounf the piviot ballsbut the a-arm is still the same so it can be used with the R2)
12) Option parts to come at the release of the R3
Carbon low degree front C-hubs
Carbon High degree front C-hubs
Center drive shaft one way
1.5 deg Carbon rear hubs
Carbon Bevel gears
So you guys with the R2`s don`t worry the R2 will still have support I asked ALEX Racing about it they will still be making parts and since most of the stuff that is for the R3 can be used on the R2
-Dave
#4959
Regional Moderator
Dave you sure its not going to be limited ? or at least that color changing chassis? I was told by my good freind there in J-land that has many ties with pal ,alex ,xenon etc etc.. that it will be limited !
#4960
either way Gliter chassis or no gliter chassis ...this car is Bad A$$
I don`t worry my self with the small details ...limmied doubt it..
-Dave
#4961
Regional Moderator
Maybe the Chassis ...but thats about it...they didn`t say one thing about it...and I even had the wife ask to to make 100% sure
-Dave
-Dave
#4962
Oh errr missus
Thanks for all the info Dave
Not sure about the glitter effect carbon chassis, looks a little toy like. No visable weave? so does it have weave thats just super fine or is it made some other way?
Sounds very nice overall, I'll probably get one in half a year or so, as a second car, so I'll have a spare for outdoors, but no huge must haves once my Cuda is sorted.
#4963
I wonder what Triox will do, I'm sure they haven't sold all their R2's, with their useless promotion and prices, and they have there's with the cells on the other side. Will Alex Racing make them any with the cells on the left?
#4964
Oh errr missus
Oh errr missus
they call it Hard pressed Cabon fiber
