Barracuda from Alex racing
#3166
R/C Tech Elite Member
Re: Re: How to use those uncentered ball studs?
Originally posted by JDM_DOHC_SiR
there are little indentations on one side of the offset 6.8mm balls... on the forward arms have this mark poiting forward...and then on the rear you can just look at the arms to see the "about" adjustment you are making..
-Dave
-Dave
#3167
Re: Re: Re: How to use those uncentered ball studs?
Originally posted by Randman
So the front ball should have the notch facing forward? I hadn't measured my toe in, but it looks like I have 2 degrees on the arm, and 2 on the hub carrier, I was really surprized. I think I'm going to mellow that out to maybe 2.5-3.
-Dave
#3169
I've never gotten a direct answer on this, but should the notch on the front pivot face forward? And should I adjust the notch on the rear pivot so it faces forward as well? I would think the width of the car, and wheelbase could be altered as well with the pivots.
#3170
-Dave
you can alter a bunch of things with the Offset balls
#3171
Re: Re: Re: Re: How to use those uncentered ball studs?
the 2.5~2.8 range is the Hot ticket Randy
-Dave
-Dave
What will be the effect or handling improvement of having 2.5 to 2.8 toe-in? Thanks
#3173
Re: Re: Re: Re: Re: How to use those uncentered ball studs?
Originally posted by S-T-R-l-K-E-R
Hi Dave,
Hi Dave,
#3174
well they didn't run the endurance race yesterday just normal qualifying then a final. I don't think I'll be going back to that club again, atleast not when it's on the wooden floor. It was one of the slipiest wooden floors I've ever raced on, normaly you can get away with wide mini pins, you HAVE to have 21mm wide mini pins there and they must be fairly new. My narrow's were fairly worn and the wheels didn't fit on my cuda anyway, they are Schumacher wheels which have huge spokes in them which foul the rear hubs and don't allow much steering.
I was skating around all night and had my repaired dodgy front diff in. Wasn't a good night and ended up in the C final in 2nd place on the grid. Taken out about three times on the first lap to put me last, ended up 2nd by the end, a couple of late mistakes costing me a first place, not that it would have been an achievment the car seemed to handle worse as the final went on, looks like my repaired diff has gone for good now, just gave it a feel and it works like a diff but you don't expect it to sound like someone snoring when just turning it gently
Ahwell, back to some decent racing with grip on monday, even if it's soaking wet I'll have more grip
#3176
Watch out if you venture into the Evo 3 thread guys
they're insulting our thread saying you have to scroll too much, what they don't realise is, it's all extra excercise for our fingers
So here's some extra excercise for you
#3178
Hahaha
Very Fun!
______________________
My Signature
The End!
Not!!!
Sorry guys...I couldn't help it. JDM_DOHC_SiR we buds right? hehehehe
Very Fun!
My Signature
The End!
Not!!!
