Team Associated TC4 >
Team Associated TC4
Like Tree326Likes
Team Associated TC4
Old 03-17-2018 | 05:52 PM
  #15616
gigaplex's Avatar
Originally Posted by JC3
Thanks guys. I'll be honest with you, as a newb I won't be stressing my diff cups to the point of breaking any time soon. My biggest enemy is the wall and my lack of experience. I do want to try 2 diffs in the TC4 as an experiment when we start running asphalt.
I bought a complete rear diff out of a never used TC4 Club for $18. I'm just going to swap it for the front diff. I'll experiment with it over the summer/fall. As I get better or put in enough time/wear on the components I can then upgrade to the lighter better parts. I'm trying to also reign in my spending since I've now got the TC7.1 to think about.
What is everybody using for diff lube? I've got a tube of the AE diff lube but I've read that there are some interesting alternatives so thought I'd ask. Thanks!
I've never broken a plastic outdrive. But they do wear out pretty quickly. They're pretty cheap to replace so if you're planning on sticking with them, get a packet or 2 of spares.
I stick with the stock AE lubricants.
THEBIGBULL and JC3 like this.
gigaplex is offline
Old 03-19-2018 | 10:39 AM
  #15617
CraigH's Avatar
Finally got to run the Kaizen on black carpet. It ran great and handled good all day. It responds to adjustments and was easy to start dialing it in. Few more changes and it should be on point. I wish we had asphalt racing here because Im sure it would really rock outside.
CraigH is offline
Old 03-20-2018 | 08:36 AM
  #15618
boudin4evr's Avatar
what aluminum steering rack is that?
bearings or brass bushings?
boudin4evr is offline
Old 03-20-2018 | 09:53 AM
  #15619
CraigH's Avatar
Gpm with bearings
CraigH is offline
Old 03-20-2018 | 03:11 PM
  #15620
Just out of curiosity, what gearing are you running? Also, what is the mount you have for the fan over the motor?
DoubleRR24 is offline
Old 03-20-2018 | 07:00 PM
  #15621
JC3's Avatar
JC3
RPM bumper upgrade complete. I removed the center section of the plastic bumper since I felt that it was just too stiff and even with the rubber grommets had no give at all. We'll see how it does tomorrow night.
JC3 is offline
Old 03-20-2018 | 07:09 PM
  #15622
Teamhotrods's Avatar
Where you running this pig? Joke. I have two.
Teamhotrods is offline
Old 03-20-2018 | 07:13 PM
  #15623
JC3's Avatar
JC3
The "pig" is being run at Queen City RC. Over the summer I hope to make it up to Dayton and Indy.
How bout you?
JC3 is offline
Old 03-20-2018 | 08:04 PM
  #15624
CraigH's Avatar
88/51 and the fan mount is exotec. Oh btw car wieghs 1400.
CraigH is offline
Old 03-21-2018 | 06:07 AM
  #15625
They just opened a black carpet place in central Texas so my first run will be Thursday night. Only a slight change from your setup is a local racer had some TC7.1 short shock and towers cut for the TC4.
JC3 likes this.
Old 03-21-2018 | 08:16 AM
  #15626
JC3's Avatar
JC3
Well, have fun! I really like the carpet. However, I've not run asphalt yet so we will see how that goes.
JC3 is offline
Old 03-21-2018 | 11:06 AM
  #15627
The asphalt track runs a spec HW X10 ESC and 3650 21.5 motor next weekend. That’s why I thought to ask where you were running. Thought we might be neighbors.
I’m going to get this thing ready for that track specifically but wanted to get some track time on that chassis ASAP to work out any issues. Not sure if black carpet is going to help or hurt me!! 😂
JC3 likes this.
Old 03-21-2018 | 01:32 PM
  #15628
boudin4evr's Avatar
Gpm with bearings
what size bearings fit the GPM?
Old 03-21-2018 | 02:07 PM
  #15629
And that's 64 pitch?
Nerobro is offline
Old 03-21-2018 | 07:46 PM
  #15630
JC3's Avatar
JC3
Just got back from a sweet 5 hour long practice. Sorry to say that the RPM bumper upgrade is kind of a fail. Hard to explain but there is nothing to hold the bumper (blue piece) from riding up over the rubber grommet and coming loose. I tried it both grommet on top and on bottom same problem, the bumper comes loose. Pretty irritating since you have to keep messing with it and it never stays put. Even with it on I broke a steering rack tonight. Maybe I'll mess around with it and see if I can improve it, otherwise it's coming off.
JC3 is offline
