Old 02-06-2011, 10:03 PM   #1
Default parking lot & drag racing
what car would you buy?
we are just kinda bashing around parking lots ( not the clean est place to run )
we use cones to set our track up
should we stick to shaft or move to belt cars
or just use 2wd cars?
what car would you go with?
hotrod306 is offline   Reply With Quote
Old 02-07-2011, 09:05 AM   #2
snellemin's Avatar
Trader Rating: 16 (100%+)
Dragsters are mostly 2 wd. So pan car based stuff. But 4wd will be easier on a dirty and/or uneven track. Shaft or belt doesn't make a difference. What I use to do was sweep and blow of the track of debris. Then sprayed it down with 3 light coats of grape soda. Why grape soda? Because it smells good and usually has the most sugar content. 6 liters is enough for 132ft and cost 2 bucks from the dollar store. Spray again when the track gets slippery over time.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 02-08-2011, 02:15 PM   #3
mxrich's Avatar
Check www.rjspeed.com for high speed low cost drag cars.
I park faster than most people drive.
mxrich is offline   Reply With Quote
Old 02-08-2011, 02:16 PM   #4
mxrich's Avatar
Old 02-08-2011, 02:18 PM   #5
mxrich's Avatar
I hate when I do that.
Tamiya Championship Series Neil Rabara Racing Forum 21236 Today 08:11 PM
