Ko Propo VFS-1 ESC
#1790
Originally Posted by Hebiki
you can probably raise the entire profile since the voltage on the IBs are so much higher than the 3300s
#1791
I NEED a profile for 12th scale QUICK... medium-sized technical layout. Who's got one before tomorrow (9am)?
#1795
We just sent in a non-working Twister 2 and KO confirmed that it is a VFS-1. It does have a modified profile loaded but is still just a VFS-1. The Twister 2.1 is the VFS-1 Pro Competition Version that has the higher thermal limit. Our Twister 2 was non-repairable with a replacement offering of the VFS-1 J model. All internals are the same but just has the power leads pre-installed.
#1796
Originally Posted by Mike Schumacher
Anyone not using the original schottky diode? I saw so many top drivers using their Twister 2.1 with Novak 36AMP diode instead! Any clue on this?
the ones pictured are probably made by Much More..
#1797
I just installed a Twister 2.0 on an 1/12. I have some set up problems. I'm supposed to hold the button down and turn the switch on and wait until the light comes on, but the light goes on when I turn on the switch. What am I doing wrong? This is on an 4 cells 1/12 using Futaba HRS receiver and digital servo without an receiver pack. Any pointers?
#1799
With the B.E.C. voltage being only 3.4 max, what does that do to servos rated at 6.0 volts? Will it make my .06 second JR z9000s perform like a 3003? I would really like to get one for my Evo IV. If that's the case, I guess I could just throw my KO 2123 FET servo in there...
Tony
Tony
#1800
Are you trying to change the program or set the esc to your Tx?
-Robert
