Serpent S411
#5462
#5463
good luck as i haven't found any updated parts.
#5466
and then order from either http://www.amainhobbies.com/index.ph...s-Serpent-S411 or http://www.serpentamerica.com/shop/home.php?cat=93
hope this helps.
#5467
just ordered an eryx to go along with my two TE's . super pumped . looking forward to seeing how the new one compares to the old .
is the kit setup a good starting point for low/medium grip carpet ?
#5468
But for the start he suggested to use the standard kit chassis and set-up and work from there ...
#5471
I'm interesting in the new Eryx. How is it's durability and handling compare to other top racing car like BD7,417v5 and T4 ?
#5472
Handling: 90/100. The car runs beautifully off of default setting.
Durability:70/100. The top deck is very fragile. Big disappointment. Otherwise plastics are pretty durable they seem.
Finish: 80/100. The ball cups are very very tight that they cause tweaking and stiffness. But not all the guys here owning S411 seem to have the issue. Some suggested to sand the inner side of the cups with drummel. Well IMO, I should not spend another $100 to do that on drummel with brand new car, should I?
Manual: 90/100. Novices will have some hard time understanding some of the intructions. X-ray's manual is better. Still Serpent manual is better than the others except X-ray.
Overall: 80/100. Some aspects better than x ray(shocks, suspension mounts), handling about the same as T4 as stock, better than BD7, Finish-BD7 and T4 are better only because of the ball cups.
#5473
the balcups only need a few packs to get loose.
and the topdeck don't like it when you hit stuff headon.
overall i like the car more than every other car i had.
and the new eryx is super easy to drive
#5474
The only top decks I've seen broken have been the 2.0 super flex top decks and only after some really hard crashes, but it can happen.
The ball cups will loosen up after a few runs, but helping them with a dremel is definitely a benefit.
For additional building and assembly tips go here, http://www.serpent.com/product/400013/tech-tips/
The Eryx is a very strong car as far as the plastics go and handling is as good as any other car out there.
#5475
Mile High Indoor Championships setup
