Serpent S411
#322
R/C Tech Elite Member
First off I would like to say what an absolute pleasure this car was to build. Fit and finish is awesome. I tried stock set up on a med bite technical track. Car felt like no other TC I have ever driven before. Tons of steering, lacks a lil rear grip. I believe I can fix that with a droop change and white springs in back and move the rear springs to the front. Also the track was a little dusty so I will wait for race conditions to change. All in all, I think I have found the car for me.
#323
Anyone know what "401428 Driveshaft adaptor delrin (2)" is? I can't confirm what it is through cross referencing parts between the standard and option list but I would imagine it is either a delrin hex drive for the wheels to sit on OR delrin outdrives for one of the diffs (most likely the spool).
#324
solid drive cup
hi guys,
i love the design
the things it dissappoint me is that i test the kit and with a slide knock
the front cup broke
did i di any thing wrong during assembly time or what???s
pls advise tks
i love the design
the front cup broke
pls advise tks
#326
photo of broken part
no spare parts till i dont know
#327
drive shaft solid axle broken
hasse,
the pic. that i posted is the dive shaft solid axle.
i notice one other thing, that is when i put the car on the stand,
i give 40% of throttle and turn to the left, the hole steering arm vibrate
like some is jam to the cvd. when i reduce the steering throw to 50%, only then is reduce the vibration. but then again corner entry will be reduce dramatically!!!!!
pls advice what is wrong with it.
that why it broke my drive shaft. it crack the `U` shape for the pin of cvd to go in
tks
tks
#329
#330
Today HK Race S411 Won !
Photo later !
Photo later !
