Like Tree16Likes
Serpent S411
Old 11-28-2011, 07:33 AM
  #1891
dawgmeat's Avatar
Originally Posted by minilantern
903332 is shocks revision kit
I don't know what you broke, e-clip? or circlip?
I believe you can get what you are looking for in here
http://www.amainhobbies.com/product_...k-Revision-Set
circlip, plus does lowes or home depot sell these item, don't wanna pay 20$ for one ring that come is that kit
dawgmeat is offline
Old 11-28-2011, 07:52 AM
  #1892
I think the link on your previous post is the way to go, IMO
its the only circlip and is listed in the manual too
but dont know why it has different shape
still dont recommend that one
what about this?
http://www.rc-mushroom.com/product_i...shocks-p-10819
minilantern is offline
Old 11-28-2011, 10:39 AM
  #1893
VexVegaz's Avatar
hey guys...
can you recommend a servo saver that would fit into a s411 and a savox sc1251mg servo, without having to mod the servo plate?
VexVegaz is offline
Old 11-28-2011, 01:01 PM
  #1894
if anyones interested i have a new 2.5 mm chassis and a new top deck (still in packet) will ship any where if buyer covers postage ..
thanks
mwoods is offline
Old 11-28-2011, 01:48 PM
  #1895
Trader Rating: 38 (95%+)
for those that have the v2 kit, or have switched to the 2.25mm chassis, is the car alot better to drive, then before, and if anyone has owned a xray before and now has a serpent, can you please tell me the advantages for this kit thanks
zaraz is offline
Old 11-28-2011, 06:01 PM
  #1896
Johnny Wishbone's Avatar
Originally Posted by VexVegaz
hey guys...
The new Xray 4 spring servo saver will work. Instead of modifying the plate, I run a double thick piece of servo tape under the servo and then put a 1mm washer under each of the servo standoffs. I tried this without the servo tape but 2 things happen. First the whole assembly, servo and plate will slightly move no matter how tight you run the screws and nuts. And 2, the servo will drop down and the saver or arm will start to rub on the plate and if you don't check it, the car will not steer properly.
Johnny Wishbone is offline
Old 11-28-2011, 06:07 PM
  #1897
2.25 plate makes the car feel more planted in the rear. There is no clear cut advantage of one over the other, both are very good cars. Shocks are a different kind of assembly/build but build and quality are comparable. See if someone at your track has either and see if you can take it for a spin, maybe one suits your style of driving more than another.
Old 11-28-2011, 06:08 PM
  #1898
duckman996's Avatar
Trader Rating: 14 (100%+)
hey guys...
I use the Tamiya servo saver (The high torque one with the aluminum mount) and use double-sided tape to mount the servo to the chassis. I only use one servo mount (the one in the center of the chassis) and it's held-up awesome so far.
duckman996 is offline
Old 11-28-2011, 06:15 PM
  #1899
duckman996's Avatar
Personally - I found the car to be pretty close when comparing the 2.5 to the 2.25 chassis'. When comparing to the XRay, I like that the S411 has a little more front end grip when using similar set-ups on both cars. The Serpent seems to like to rotate a little more - it feels less "pushy".
Old 11-28-2011, 06:20 PM
  #1900
jbenthobbies's Avatar
thanks
shoot email to [email protected]
jbenthobbies is offline
Old 11-28-2011, 06:22 PM
  #1901
I have owned both. Cars are very good, The Serpent seems to complete the whole corner better.
Old 11-28-2011, 07:48 PM
  #1902
thanks all for the input, i placed an order for the limited edition, any hop up I should get , the dual cvd, for the front, also will the xray lipo battery holder work on the serpent, thanks
zaraz is offline
Old 11-28-2011, 09:11 PM
  #1903
double the heatshrink in the DJC to help it hold the pin better
what is the problem with the carbon battery holder?
Old 11-29-2011, 04:41 AM
  #1904
mattwoodcraft's Avatar
if your refering to the brace that goes across the top so no tape is needed yes it does. i use the corally one because i dont like taping the batteries down maybe im lazy
mattwoodcraft is offline
Old 11-29-2011, 07:31 AM
  #1905
yes i do not like tape, looks cheap in such an expensive kit lol, plus i just like the added security of the brace also it says it does not tweak the chassis, can you take a picture of the corally brace thanks
zaraz is offline
