one way
how does a one way affect steering? does it give the car more steering or will it make it push more? i am new to TC"s
More steering but no brakes!
a 1way will also heat up/overheat the front tyres more, than a diff or spool. but is an awesome tuning tool in stock racing where breaks usually arent used anyway. in addition it will give more 'kick' to the exit speed of low speed corners.
That's odd, because I always tend to "break" more when I drive with no "brakes".
;) Wassup Johnny!! |
ha..............ha:p
A one way diff is harder on the front CVD's. So if you want to try a one-way diff someday, also get steel CVD's up front.
One-ways are best suited for high bite, large tracks. You can read more here. |
Originally posted by s2 a 1way will also heat up/overheat the front tyres more, than a diff or spool. but is an awesome tuning tool in stock racing where breaks usually arent used anyway. in addition it will give more 'kick' to the exit speed of low speed corners. |
I agree with what Cole Trickle mention a while ago... I also use my spool in some tracks ...
