Hot Bodies cyclone setup >
Old 01-16-2011 | 02:15 PM
Questions?? Hot Bodies cyclone setup
Hi could anyone advise me what camber/toe and suspension settings i should use in my hot bodies cyclone its a car that a friend has lent me while i get my schumacher mi4LP fixed and sorted with steel driveshafts.
Or maybe would you advise me to use the same setup as the schumacher ?
Also what pinion would you advise me to use ( the spur is standard )
cheers
James
jwright1 is offline
Old 01-16-2011 | 05:11 PM
go check out hotbodiesonline dot com and look for the setup sheets for that car.
cwazyduck is offline
