Best shocks to use for on road touring
Hi,
Just wondering what are the best shocks to use for indoor carpet for 1/10th touring. How and why they are good and any first hand experiences.
I would say they are all good.
Personally.
Tamiya (Because they dont leak, and are aluminum (TRF))
Associated (Because they are aluminum)
Xray (because they came on my car - Adjustable dampening with variable holes).
I really dont like the Plastic Xray shocks because the bottom cap is a pain in the but unless you buy the Hudy Shock Tool.
X-RAY plastic shocks don't really need the Hudy shock tool,i've made two set's without the tool and work perfectly.
+1 on the the trf dampers.
keep the shafts clean from dirt and carpet fibres after every race meeting or 2 and they will serve you well for a long time
Have to agree. Tamiya's TRF shocks are 100% rebuildable and bleed vary little, or not at all.
+1 for the Tamiya TRF shocks
and the T.O.P. V2 shocks are very close if not equal to the TRF shocks.
trf dampers, nothing more to say!
tamiya/top are great.
Xray also but hard to get it right.
the hotbodies were also good. I didn't like the yokomo's.
TRF dampers 100% no leaks easy to rebuild. Most of the guy at the track I race at use TRF shocks on diffrent mfg chassis.
well...
In many ways it depends on the car you have. each shock absorber set is made by a manufacturer for the car - having regard for the wishbone length, wishbone holes, shock towerss - basically the geometry. a longer shock will 'pack' differntly to a shorter shock, so a change of one shock on a car to another brand is likely to result in a different set up.
I see a lot of people change XRAY shocks for TAMIYA TRF's coz they are a better shock than the XRAY. Unfortunately they are a bit shorter, and you won't be able to try 'team' driver set ups without altering and compensating for a shock change.
Before getting into a change of shock, why not try this:
1. buy some much more o-rings;
2. buy a shock pump, or make one with a fishing air pellet air remover
3. get the ball joints to move very smooth and freely.
As to XRAY shocks, I am told the ATOMIC RC alloy bodies are an excellent upgrade.
