Team Corally RDX Touring Car >
Old 03-22-2005, 06:29 AM
  #1456
Originally posted by Dhartman03
This is one amazing car, I ran a box stock US carpet spec kit, and was able to place in the top ten twice in the qualifing rounds.
DH
It is a great car and as Rob says "it just works".
Monte Hess is offline
Old 03-22-2005, 06:37 AM
  #1457
ExcelRC's Avatar
syndr0me- Narrow hexes are on the way...probably not until thursday though. Are you going to make it to the 'Lane wednesday?
ExcelRC is offline
Old 03-22-2005, 06:50 AM
  #1458
Brian McGreevy's Avatar
Raul, are you running the narrow hexes in the rear? If so, what did it do for the car? I'd figure that it'd steer better...
Brian McGreevy is offline
Old 03-22-2005, 07:09 AM
  #1459
John Fontaine's Avatar
This is the first I've heard of narrower hexes. I bought the US spec car about a month ago, i'm curious what I got in my kit?
John Fontaine is offline
Old 03-22-2005, 07:39 AM
  #1460
Big thanks to Rob Michaels and members of Team Corally for there support at the Nats. Setups to try, lots of parts, and advice that helped a bunch.
Big congrats to new team member Furman Walker who was ballistic in 19t and had just enough bad luck to ruin some great runs.
barnacle is offline
  #1461
syndr0me's Avatar
Trader Rating: 32 (100%+)
Excel,
I'll be there, and I'm good for 2 or 4 narrow hexes once you get them. :-)
syndr0me is offline
Old 03-22-2005, 08:37 AM
  #1462
Turbonium's Avatar
Trader Rating: 27 (100%+)
i looked for the part # but didnt see it. i got them separate from the kit, as they come with the wides.... but they were black as well. i think they are still in the package at home, so ill look this eve for the #...
Turbonium is offline
Old 03-22-2005, 10:18 AM
  #1463
Part number is: 79141 packed in pairs.
modeltech is offline
Old 03-22-2005, 10:36 AM
  #1464
Ok, so if the narrower ones are optional then I have the original wider ones with the kit. Thanks!
Old 03-22-2005, 10:42 AM
  #1465
rayhuang's Avatar
Yup-YOu should think about one set for the rear so the rear of car will be 190mm.
rayhuang is offline
Old 03-22-2005, 11:51 AM
  #1466
My car was still a little over with the narrow hubs and Parma Tires,
(190.10), but it fit in the tech box at the nats.
Jim D.
ukeejim is offline
Old 03-22-2005, 01:46 PM
  #1467
Default width
has anyone run jaco tires on the car.
i ran double pink/orange (front) and double pink (rears)
the jaco's were right on at 190mm in the rears
but 188~189mm in the front. all with the standard (wide) hexes.
is this what everyone else is coming up with as well.
i was thinking about adding one more set of shims at the front bulkhead to bring the front to 190mm or else creating toe in/or out from the bulkhead rather than from the turn buckles.
any comments?
Electro-MAX RC is offline
Old 03-22-2005, 02:00 PM
  #1468
seaball's Avatar
Id just like to thank the Team Corally guys for fixing my car at the nats when it broke in a false start, and the support they gave me at the race. This is one amazing car, I ran a box stock US carpet spec kit, and was able to place in the top ten twice in the qualifing rounds.
DH
yup, danny and his car were awesome all weekend. i thought i was in trouble when i couldn't run with him in pracitce. but later, i realized just how good danny was running. w/o qual points it would have been a-main for mr. hartman. perhaps he will be in a few weeks at The Gate, for our season finale.
bring it, danny!
seaball is offline
Old 03-22-2005, 02:09 PM
  #1469
Trader Rating: 79 (99%+)
Default narrow hexes
Brian, I have not tried the wide hexes, I am running a box stock kit... But yes , narrower would make it turn easier.
Raul Garcia is offline
Old 03-22-2005, 03:08 PM
  #1470
Jeff Brown's Avatar
Default Re: Car Width
Originally posted by Brandon Melton
Does the car measure at 190mm out of the box with foams?
Does the kit come with the narrow or wide hex adapters? I would like to space the front tires out some more to be able to get the tires to turn further without rubbing the spring, but don't want to make it past the 190mm.
Kits are supposed to have standard hexes. Narrow hexes are an optional part. However, if you received one of the first 10 Carpet Spec kits they had narrow hexes on them. No kit from now on will have narrow hexes.
They are all black hexes. I have some silver standard ones but those are earlier versions.
No it does not equal 190mm out of the box. I added 3mm on each side at the Birds with JACO tires to get 190mm. It might have been wide, but I measured it like 5 times. I believe it is different for PARMA tires.
I left the shims on and put rubber tires on and it is dead on 190mm in the front. The car is more stable and does not roll over in corners with the wider stance. I noticed better overall steering along with another driver I told to do it.
The rear with 2 deg of rear toe (2 shims) is 190mm. Some guys add the narrow hexes and put 2mm shims on the arms to space them out. Hope this helps.
Jeff
Jeff Brown is offline
