Team Corally RDX Touring Car
#1276
Try Superior Hobbies, Fla
#1277
Originally posted by ground-round
Just got my RDX this weekend. I've been building it a little bit every night and all I can say is WOW! This thing is going together beautifully. I've been an Associated guy for the past 6 years and the difference in the manufacturing tolerances isn't even close. Build the RDX like the instructions say and its perfect. Build a TC3 or 4 from the instructions and you've got a trainwreck.
Get another bottle of Jack Daniels and your good to go
#1279
THANK YOU!!
Just got off the phone with Chris, got the last one! Can't wait to get it.
Originally posted by DJG24
RC Madness has them in stock. Get the phone number off of the website. www.rcmadness.com
#1280
Glad to hear it!! Chris is a great guy to. Glad he could help you out.
#1281
Would someone be willing to post a picture of there rdx, i remember seeing one a while back but can not find it.. i would just like to see how things are layed out and that im going to be using the picture for my programing class. So if you guys dont have a problem with this request i would greatly aprciate it.
thanks,
lazy
oh ya, and i need something to look at while i wait for mine to come
thanks,
lazy
#1283
Originally posted by Brian McGreevy
Preston, here's a pic of mine...a bit old now, though.
#1284
slammed frt tower
Ok. I just finshed assembling my car, it's now 2:am. Tommorrow is race day. But I have a problem. I modified the frt tower to lower it, and added spacers to limit travel in the shock, but am I am confused because the spring cup is almost bottomed on the body, meaning hardly NO uptravel.?? What am I doing qrong, andcan someone please help. Thanks.
#1285
Raul- Get you some Losi, AE or x-ray spring perches.
#1286
Re: slammed frt tower
#1287
Raul..... no one runs spacers in the shocks. remove those and use the drop screws to set up travel. Get some losi spring perches as well.
Jeff
Jeff
#1288
McGreevy- In your set-up on the other page you are running the optional roll blocks w/ the stock to get 2deg of anti-dive and 2deg of pro-squat in the rear. How do you position those?
Front- Low block down/ std. block up? Or will just the off-set yield the 2degs. with both blocks up or down?
Same thing in the rear I would think.
#1289
Roll center blocks
imprsme,
I think I can answer for Brian, if you mount the optional low roll center mount in the front hole of the bulkhead with the hole down and then mount a normal roll center mount in the rear hole of the front bulkhead with the hole down, you would end up with -1.6 degrees of anti dive. Do the same to the rear of the car and -1.6 degrees of pro squat.
Steve
Steve
