Team Corally RDX Touring Car >
Old 01-08-2007, 03:28 PM
  #9976
mike nelson's Avatar
Originally Posted by gone_wheelin
Okay, here's a question for you guys. Will the new center post steering work with the non-spec chassis? I'm looking at the images and it looks like the SPEC chassis is a little different than the stock, particularly the placement and number of mounting points.
The center post steering mounts off the top deck, doesn't touch the actual chassis.
Attached Thumbnails Team Corally RDX Touring Car-dscn0424.jpg   Team Corally RDX Touring Car-dscn0425.jpg   Team Corally RDX Touring Car-dscn0426.jpg
mike nelson is offline
Old 01-08-2007, 04:37 PM
  #9977
gone_wheelin's Avatar
Mike- Thanks for the pics and the explanation. I thought that it connected through the chassis to the top plate.
gone_wheelin is offline
Old 01-08-2007, 06:43 PM
  #9978
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by mike nelson
Here are a couple pics of my car from the Novak Race, car was extremely easy to drive. Rob has my set up sheet and he will be posting it on the Corally web site.
The center post steering worked awesome, I just sanded a little off two standard ball cups and put a .080 spacer between top deck and center post.
Jeez Mike, I was expecting a setup sheet when I clicked on your attachment, not the results. Nice job at the Novak race and thanks for your help!
Kraig is offline
Old 01-08-2007, 07:39 PM
  #9979
i just wanted to say thanks to the Corally crew. they were a ton of help. especially Toso and Robbie. The car was really good all week at the Novak but found out after the Novak that i had a bad cap on my speedo. still put it in the B but should have been in the A. thanks again to the Corally crew.
goop is offline
Old 01-08-2007, 08:11 PM
  #9980
Trader Rating: 16 (100%+)
Good pictures Mike.
I have this excellent mod on both my carpet and asphalt cars.
I also used a small rat-tail file to slot the holes for the ball ends outward to give the ball cups more clearance with each other.
Considering making a small plate to reposition the ball ends beyond the end of the center lever assembly to get mounting points closer to front pulley. But, it would be really nice if Corally could give us a fully modified center lever assembly to take care of that issue and the poor geometry angle of the steering turnbuckles (without having to use special jointballs).
Still Bill is offline
Old 01-08-2007, 09:07 PM
  #9981
brian cox's Avatar
Trader Rating: 90 (100%+)
any of you guys know what the part number for the tamiya 3 hole pistons that some guys show on the set-up sheets?
brian cox is offline
Old 01-08-2007, 09:10 PM
  #9982
Trader Rating: 34 (100%+)
RC TRF Damper Piston 3 Hole Item #53573
CraigX is offline
Old 01-09-2007, 04:00 AM
  #9983
Vicko's Avatar
Trader Rating: 14 (100%+)
damn x-man get some sleep, oh by the way I got my car in the process of rebuilding it, so why do u come to the track and I'll just give u the car so u can rebuild it for me
Vicko is offline
Old 01-09-2007, 01:10 PM
  #9984
Trader Rating: 27 (100%+)
On some of the set up sheets from corally.com, they have droop at 7.5 and 8.5 (rubb/carpet) then others say 2.5 up (which is off ride heigth, i assume) well is there another way of checking, the manuel inst very clear. Any other advice for rubber/carpet would be helpful. I ussually check droop of off ride height and 7.5 seems insane, I am new to the car
convikt is offline
Old 01-09-2007, 01:19 PM
  #9985
Anytime you see a number like 7.5 for droop, it refers to uptravel. Uptravel is measured by how far you can lift an end of a car from static (resting) ride hieght to where the tires just start to leave the ground.
So if your ride hieght is 5mm, and an end of your car lifts to a total distance of 7.5mm, measured from chassis to ground, to where the tires just start to come off the ground, you have about 2.5mm of uptravel.
hope this helps.
Obsidian is offline
Old 01-09-2007, 02:06 PM
  #9986
lol...duh..it helps a lot. I sometimes cant add 2+2
convikt is offline
Old 01-09-2007, 02:18 PM
  #9987
Hey Still Bill,
How did you do at the NWCC?
Obsidian is offline
Old 01-09-2007, 03:31 PM
  #9988
syndr0me's Avatar
Trader Rating: 32 (100%+)
*looks nervous*
syndr0me is offline
Old 01-09-2007, 06:38 PM
  #9989
Vicko's Avatar
yo any know where I can fine those metal supports for the rdx shock mounts at? or give me an link to where i can buy them
Vicko is offline
Old 01-09-2007, 07:36 PM
  #9990
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
www.teamtamale.com
Mr. McGoo is offline
