Team Corally RDX Touring Car >
Old 01-29-2006, 11:56 AM
  #5461
RDXracerboy's Avatar
Originally Posted by kartermdb
just grab ur layshaft with a pair of pliers softly and turn it off, ive had to do this in the past, then just get another screw for it, or you can be lazy like me and just keep the stripped one and use pliers for a few months, lol, its an old wheel screw from the old C4 and C4.1
anything can cause these cars to be loose, what are you using for difflube when you build ur diffs and how much are you using?
I'm using the one that came with the kit and I put some on each plate on both sides, also on the diff balls. Quite a bit but not too, just enough to cover them up.
RDXracerboy is offline
Old 01-29-2006, 12:05 PM
  #5462
kartermdb's Avatar
Trader Rating: 15 (100%+)
your diffs prolly feel alittle slow and sluggish then, they will break in nice and should come around after about a full race day, i only put lube on my diff rings, cause i find even that can be too much sometimes
kartermdb is offline
Old 01-29-2006, 12:27 PM
  #5463
Oh ok thanks, another thing is when I turn sharply I hear a weird noise coming from my diffs, I think its the belts riding up on the pulley walls? not sure though.
Old 01-29-2006, 02:04 PM
  #5464
kartermdb's Avatar
that is probably your front cvd's making the noise, did you make sure they were able to move in full rotation before you put them on the car?
Old 01-29-2006, 05:12 PM
  #5465
Yea they did rotate all the way before I put them on. It sounds like it's the belt that's why I thought they were probably riding up but not sure, I'll check my CVD's to make sure they are ok.
Old 01-29-2006, 05:26 PM
  #5466
Ive got a bit of a problem with my RDX and its Pisssing me off
I have a striped spur gear and i need to change it....the only problem is that the screw that holds the assembly is rounded off and you cannot get no grip what so ever. I need to get this sorted soon, has any one got any ideas on how i can get my spur out and get this stupid rounded screw out.
P.S what spur gears will fit the RDX without buying/doing and mods
Ta,
Wills
Heat the screw wil your soldering iron, this will allow the plastic to melt around the screw and take the pressure off of it. This also helps loosen loctite if any was on. Best of luck to you.
Cammer is offline
Old 01-29-2006, 05:51 PM
  #5467
Customworksking's Avatar
Trader Rating: 74 (100%+)
Talking push
list a few things I can do to get my car to rotate faster I ran this weekdend In St Louis Drew Ellis had his T-2 carving big time I could not free the rdx up AT ALL 1deg toe in 2/2.5/3 mm uptravel rear.... 1 1.5 2 mm uptravel FT 4deg caster 6 deg caster,Kick-up 30 33 LB springs Ddl pink orange ft 1/2 toe in 1/2 toe out 1.6mm sway bar no sway bar 3.9 chassis tamiya 2 hole 45wt shocks long camber link/short camber link..tried it all not more than 2 things at a time TQ 3rd in the A but got killed in the infield No matter what other than little or no dope on the rears did it get loose but too loose or shall I say not the "fast" loose/free needed turned in fine but mid and exit had a very small push say A tenth or 2 ..put it this way there was 8 cars in the main 2 corallys and ALL xray T-2's I TQed 3rd if I had A bit more on-power I could of done better minus Drew E he's a team Driver and a Very Nice guy I might Add any help will do
Customworksking is offline
Old 01-29-2006, 06:07 PM
  #5468
Soviet's Avatar
Punctuation would be nice.
Soviet is offline
Old 01-29-2006, 06:23 PM
  #5469
Try some anti-squat next chance you get or stiffer spring in rear. Also, try different ackermann positions. I generally run the outside hole on rack and steering knuckle.
barnacle is offline
Old 01-29-2006, 06:24 PM
  #5470
Jeff Brown- Any chaka kahn sightings recently??
barnacle is offline
Old 01-29-2006, 09:22 PM
  #5471
Arrow
all in all I just need more on-power steering
Old 01-29-2006, 09:39 PM
  #5472
Korey Harbke's Avatar
I would try going to 6 deg of caster, tightening up your front droop screws a touch. You could also try running std roll blocks in the rear and low rolls up front.
-Korey
Korey Harbke is offline
Old 01-29-2006, 09:44 PM
  #5473
Default car
got it .............thanks
Old 01-29-2006, 09:51 PM
  #5474
You can also just take out some rear toe in. I run 1-1.5 deg almost all the time on foam.
-Korey
Old 01-30-2006, 02:23 AM
  #5475
Further to the problem of diffs. loosening off..........
I've been sitting here thinking never had that happen - hah.
Last couple of race days my rear diff comes loose!! On close inspection I think that the plasticky lock nut is not seated fully in the outdrive, so while running if it moves a smidgin and hey presto loose diff. Something to check.
Cheers
Peter
Pedro 51 is offline
