Team Corally RDX Touring Car >
Old 09-20-2005, 06:13 AM
  #3406
DougC's Avatar
Default Front bearing holders
Does anyone know if there was a change to the front diff bearing holders? I just got my US Carpet car and it included two pairs of the, rear, offset bearing holders. The instructions call for a holder that has the bearing centered.
DougC is offline
Old 09-20-2005, 07:37 AM
  #3407
imprsme's Avatar
Trader Rating: 91 (100%+)
There are two sets of bearing holders and two different size bearings. The ones for the one way are centered and require the bigger bearing and that is the one the instructions are written for on the front of the car. For the diff and Spool the bearing holder is off-set with the smaller bearing. So that you can run them high or low.
So in the Carpet car you should have 4 of the off-set. Hope this helps.
imprsme is offline
Old 09-20-2005, 07:39 AM
  #3408
DougC's Avatar
That does it. Thank you very much.
DougC is offline
Old 09-20-2005, 07:51 AM
  #3409
imprsme's Avatar
Glad I could help! If you have anymore problems feel free to ask here or you can PM me!
imprsme is offline
Old 09-20-2005, 08:05 AM
  #3410
Jeff Brown's Avatar
Originally Posted by gc2005
Okay, I guess you splice the fan leads into the + and - battery wires but where does the switch go? Yes, it's time for electronics 101.
The negative wire goes straight to the fan. The positive goes into the switch. Then back out the switch on the other side. Thus you will have an "open" circuit in the OFF position.
Jeff
Jeff Brown is offline
Old 09-21-2005, 06:30 AM
  #3411
Default RDX AMAZING CAR !
hi guys!
i've just tried the rdx for the first time last night and i am surprise how well the car handeld very well and i can see the difference between my xray fk04
and the rdx is more suited for my style of driving !!
keep the good work corally !!!
awesome machine !!
Pete68
pete68 is offline
Old 09-22-2005, 01:24 PM
  #3412
Mission_carbon's Avatar
So are u going to get one then? beast of a car
Mission_carbon is offline
Old 09-23-2005, 07:50 AM
  #3413
Trader Rating: 50 (100%+)
does this car come with 48 or 64 pitch spur gear????
josh short is offline
Old 09-23-2005, 07:55 AM
  #3414
squarehead's Avatar
Trader Rating: 75 (100%+)
The kit includes a nice 48 pitch 78t spur gear. I replaced mine with a 104t 64-pitch PRS oval Pro Lite spur. It's the exact same overall diameter as the 78t kit spur.
squarehead is offline
Old 09-23-2005, 06:24 PM
  #3415
Jeff Brown...
is your fan mod on sale now.... my hand is itching and want to get a hold of one.
now.. where is my rear upright that mike from corally usa promised me??
called corally on monday and they said they will ship it out the same day..
and I have not get it yet....
I want my alum rear upright that was missing from the packaging...
soo bumm.....
~Ming
aoizip is offline
Old 09-24-2005, 01:17 PM
  #3416
Glowster21's Avatar
Trader Rating: 136 (100%+)
Hey guys...Having a Roll Center brain cramp. How is it adjusted on the RDX and what are the benefits from having a high/low roll center? I run carpet and know I need a low roll center and am planning on getting the low roll blocks...what positions on the bulkheads should they go in? Again...having a major brain cramp and still learning many of the touring car terminologies.
Thanks!
Joe
Glowster21 is offline
Old 09-24-2005, 02:03 PM
  #3417
imprsme's Avatar
Glow- For carpet I prefered the low blocks in the low holes with the "dimples" low! LOL
imprsme is offline
Old 09-25-2005, 12:14 AM
  #3418
syndr0me's Avatar
Trader Rating: 32 (100%+)
What topdeck is this? And for that matter, what chassis? Says Corally USA on the topdeck. :-D The chassis kind of looks like that BMI prototype.
syndr0me is offline
Old 09-25-2005, 06:15 AM
  #3419
squarehead's Avatar
Yeah, an educated guess, based on milling style, typography used on the plates and general proximity/relationship of BMI and Corally USA, I would say it's probably a BMI item. Man, that top deck is THICK.
Old 09-25-2005, 06:58 AM
  #3420
Smile
Looks like the work of BMI, they like to put the name of the car on the top decks of there products. The front shock tower is also different, must be the lowered one they have been working on.
XCELL is offline
