Team Corally RDX Touring Car
#2446
Pretty sure it is and the only difference is its threaded on one side to hold the pin for the steels caps.
#2448
JayBee- the bones are no weaker than standard bones. Just drilled on the very end for a set screw. I don't think a 1/4" is major. You could put some kind of a white line on it if you wanted and check to see if it is rubbing through the corners. If you are running at like 3mm ride height then it might be close in the corners.
Jeff
Jeff
#2449
Better safe than sorry. I damage one of the brush hoods yesterday in a side impact. Pics is a motor endbell guard made from an old plastic bumper.
#2450
Nice electronics layout and wiring too!
I like it!
I like it!
#2451
Yeah I bashed a tube in on my V2 as well. I guess it is just unusual cause motors have been inside the chassis in the past. I think you will find damage to most motors but usually you can fix it up ok. The hassle is the brush shunts being ripped apart.
Hey cookie... saw and hacked abott on the weekend (kinda my mistake) but didn't see you!
#2452
Not surprised you didn't see me! As I was at TFTR club day racing! Awesome fun :-)
Can't wait to Winter Champs, only 2 weeks now! Will be awesome! Especially to see Hara, Karn and Teemu going flat out!
#2453
Originally Posted by Turbonium
it holds 3 boxes, which measure..:
9 3/4 wide, 5 1/4 tall, and 19 long each, outside dimensions. very nice black boxes, with a red Corally label on each. the bag itself is...
16 1/2 tall, 10 1/4 wide, and 19 1/2 long. nice heavy duty zipper, and a pocket on the side.
the boxes will fit a electric touring car with the body on easily, in case anyone was wondering...
#2455
Originally Posted by Obsidian
Greetings,
What does the updated thrust bearing look like (color, shape?). I remember reading somewhere that there was one version that failed fairly easy.
#2458
Hey guys I raced my car outdoors on a med bite track and I experienced some roll problems with the car. I'm running 60/40 wt oil, low roll center frt/rear and my camber links are mounted all the way out on the lowest hole. How would you guys try to controll the roll, would you do it roll center, suspension or with swaybars. By the way, those of you that run on asphalt do you use the swaybars??
