Heating plastic suspension parts?
I recently read a tip - can't find it now, but it must have been in RC Driver or Car Action - that you could take some slop out of your suspension by heating the plastic parts with a heat gun. They would shrink a bit, and get tighter on the hinge pins.
This sounds great for me, but before I go ahead and melt my car, I want to ask you if this is something people actually do with good results?
One of my cars (Tamiya TB-01) has a fair amount of slop even with brand new parts. Do you think it would be a good idea to try this method?
I have also heard something about boiling plastic parts to improve durability. Is this something people do in general?
ok .... i've been told that u can boil the plastic parts ..
wat it does is make it harder..... becomes stronger
i've tried this once on plastic centre pulley an it did afterwards fell alittle harder ....
i don't kno bout the heaT gun ...
Instead of using a heat gun to soften the parts, why not try using spacers/shims first? As for the boiling of plastics, it doesn't actually make the part harder. By putting moisture into the plastic, your making the part slightly more flexible. This allows the part to give a little during a collision. Harder = brittle = broken part. Boiling only affects certain plastics i.e. nylons.
We used to boil nylon offroad arms to make them softer. Boiling actually anneals the arms (reduces internal stress) which allowed for more flex so the arms wouldn't break during a crash. With the graphite arms of today, heating won't due much good, and it certainly won't make them stronger.
If you need stiffer parts, look for new designs of graphite from the manufacturer or aftermarket parts. Xray made several revisions of the car arms to increase the stiffness by changing the arms design and not the material.
another way to get slop out is apply a thin wall of CA glue to the holes and test fit for slop, add another wall if theres still play or use a drill bit to enlarge if its too tight
use shims for side way play. <---->
How long do I need to boil it up??.. 1 mins 2 mins??.. just asking for clarification....
bake at 350 for 20 minutes, then when a slight goo apears flip carefully.
Guest
Re: Heating plastic suspension parts?
Guest
Re: Re: Heating plastic suspension parts?
Originally posted by Neil Rabara
I don't recommend it. If you heat up plastic, it will cool and warp changing the characteristic of the part. Not to mention geometry.
Pink arms anybody ?
Bryan
Guest
Originally posted by WC
DO NOT BOIL the parts in your TB01/TG10/TL01/FF02 as the plastic parts are NOT nylon! They will not survive heating.
Bryan
