Crystal interchangable?
Does anyone know if I can use Futaba 3PK crystal (TX) in an Aitronics M8?
No, you can't !
You can try it, there may be some overlap and glitching could occur.
general answer on crystals
I have heard it both ways. I have seen one company say that the radio makers claim you need to use their crystals because they want to sell you their own brand at heavy markups.
I have read that you should use a matched pair from one manufacture. I have seen it said you should use the brand of the tranmitter. I have receiver which insists it will only work if you use crystals from them. Does anyone have real information on whether there are real differences. |
It wont work, I've already tried it.
27mhz AM and FM are generally interchangeable (for sure on AM) 75 mhz AM & FM are rarely interchangeable. The only swap that I have had successful on 75 AM was KO and Airtronics.
I agree to slot. I've been doing this when I have the same freq on the track 27mhz AM band. In FM band I haven't tried it... :nod: :cool:
I take it you are saying that on the 27mhz band the different brands are interchangeable; i.e you could use 27 mhz AM Futaba Crystal on a 27mhz Airtronics transmitter or receiver
not that you could use 27 mhz AM crystals on a 27mhz FM transmitter and receiver. |
just got an m8 on 27mhz and tried my ko 27mhz crystals in it and it would not work. both are fm
| All times are GMT -7. It is currently 08:54 PM. |
