3Racing Sakura Zero S
#1156
Hi guys,
I bought a Zero S this week and the '19T Center Pulley Set' + additional parts as well.
Now what FDR do you guys recommend to start with, the motor is a 2600kv.
I thought around 4.5, maybe?
thnx
thnx
#1157
If you don't have a cooling fan 4.5 would be a safe starting point. My motor started to get warm enough to be out of my comfort range at a 4.0. I also had the car bound up because it was my first tc chassis so I'm sure that didn't help the temps. Now I can run a 3.7 on twin cooling fans and I come off less than 120. Motor is a ballistic 25.5 run for vta.
#1158
Yes they do. Its best to learn what you have and then change something. Relearn the car and add something else. I waited a while to get the sway bars so I could understand what was happening. If you jump right in and add all the options without understanding what is going on you will never get it tuned right.
#1159
Zero Force 3 Racing Sakura Bearing Set (12 pcs)
#1160
Which mount should i get if i want less toe in in the rear for drifting.
I saw that i has the 2 and 3 in the box but what if i want less.
I found the optional alloy ones but can't figure out which does what.
seems to be adjusting the antisquat than toe.
#1161
The numbers are for toe. rr 0 is 0 degrees. rr 1 is 1 degree etc. don't forget the pivot balls for the aluminium mounts.
#1163
Will a 35t pinion and a 78t spur fit in this car?
#1164
What pivot balls for the aluminum mounts??
#1165
6mm ride height. Almost no droop up front slightly more in the back. Sorry I don't have my exact droop numbers but they are pretty low
#1168
I'm gonna use the horizontal mount first. But I wont like the pinion to eat my chassis , just curious to know what the biggest pinion is that will fit in there. Maybe somebody else knows, thnx for ur help 6376vette!
#1170
http://www.teamassociated.com/parts/details/3987/
http://www.teamassociated.com/pdf/ca...droopgauge.PDF
I have my droop set to 3 in the rear and 6 up front.
Ride height is set with the plastic clips and my car was originally set at 6mm, but I now have it down to 5mm. I have lots of clips from numerous previous cars and can set it quite easily with the clips.
