3Racing Sakura Zero S >
Like Tree2Likes
Old 10-10-2011, 04:41 PM
  #706
Trader Rating: 19 (100%+)
What 64 pitch gear combo can I use on this car to get an 4.0 fdr without dremeling or modifying the car?
429racer is offline
Old 10-10-2011, 04:43 PM
  #707
texastc's Avatar
Believe I'm running a 46/100 or 47/100.
texastc is offline
Old 10-10-2011, 04:44 PM
  #708
I use Robinson 45/96. Also gone up to 49/96.
Batfish is offline
Old 10-10-2011, 04:46 PM
  #709
Trader Rating: 29 (100%+)
Been using 42/90 on my son's car.
JustMe2 is offline
Old 10-10-2011, 05:31 PM
  #710
Cool, thanks for the help!
429racer is offline
Old 10-12-2011, 10:26 AM
  #711
hope you can help, been recommended the zero s over a schumi mi1 as a budget touring car, but not able to find many places stocking it in the uk.
so, assuming i'm going to be brave and order from HK (or maybe europe?) can you recommend me what to get as a full spares/hop up package?
not worried about going carbon, but thought if i got everything in one go, would save time assembling and probably save me postage as well?
any advice (and parts numbers?) gratefully received
frst is offline
Old 10-12-2011, 10:31 AM
  #712
Monkeys punk's Avatar
I got mine from much more uk (rcracinguk) via reality racing. If you search on eBay kieth from muchmore uk has a eBay shop that has them in stock for £99.00. User name rcracinguk.
Monkeys punk is offline
Old 10-12-2011, 10:42 AM
  #713
Pro10noob's Avatar
In europe you can try http://www.the-border.com/home.php?cat=804
or http://www.lmi-racing.com/0000009c820b79701/index.php
regards Roy
Pro10noob is offline
Old 10-13-2011, 08:46 PM
  #714
Default Question
I was just wondering, what weight diff lube should I use if I plan on drifting with my Zero S? This would only be for the front end, the rear end I am using a solid axle. I am also setting up CS, so I am not sure if this would affect it or not.
Repulse is offline
Old 10-15-2011, 03:55 PM
  #715
LOSI123's Avatar
Trader Rating: 63 (100%+)
Need some help:
the rear dog bones are to long and cause the rear end suspension to not be able to compress, even when spaced in the middle with foam or orings, are the 46mm dog bones that are available shorter than stock kit ones?
also are there rear complete cvd's that fix this (shorter)?
LOSI123 is offline
Old 10-15-2011, 04:01 PM
  #716
Pro10noob's Avatar
Best is to use the 44MM and if you are going to use the Sakura X1 rear arms go for the 42mm.
This will stop binding problems.
regards Roy
Originally Posted by LOSI123
Need some help:
the rear dog bones are to long and cause the rear end suspension to not be able to compress, are the 46mm dog bones shorter than stock?
also are there rear complete cvd's that fix this?
Old 10-17-2011, 05:58 PM
  #717
spring71's Avatar
Smile
Sakura Zero S kits and parts are restocked from 3racing at TQ RC RACING.
Click here to see the back stock list.
FYI, thanks.
spring71 is offline
Old 10-17-2011, 08:23 PM
  #718
texastc's Avatar
FYI, thanks.
man you rock. BTW got my order today, thanks again!
texastc is offline
Old 10-20-2011, 04:59 AM
  #719
BCZero's Avatar
Quick one for someone running the narrow chassis...
Apart from the narrow susp mounts, is there anything else needed specifically for the narrow chassis upgrade, or does all the other gear (ie arms, universals etc) fit fine?
BCZero is offline
Old 10-20-2011, 05:15 AM
  #720
Pro10noob's Avatar
Get some narrower axles as they will bind running the gear diff
I used 44MM at the rear.
You can also use the Sakura X1 rear suspension arms to narrow the rear.
That way you don't need the suspension blocks.
regards Roy
