3Racing Sakura Zero S
#2056
unless you mod the motor mount like I did, the vertical motor mount is almost a must. I have the same adjustability of my Zero with vertical motor mount does with the one I modded to be like the tc6 mount. I didn't use the 19t pulley (got the stock one to work pretty well and belt fairly loose...) because the aluminum spur adapter and layshaft weren't available at the same time to buy.
#2057
Shock pops off ball stud
Hey there Everyone,
I raced my Sakura on Saturday and she handled great!!! The only issue I have had is that the rear shock occasionally popped off the ball stud during some hits from behind from other drivers. Anyone have a suggestion about the the ball caps, besides not getting hit
Thanks of your all's help again. I love this forum, and how everyone helps each other!!
#2059
Thank you Ocean. I should have been a little more specific on which end was popping off. It is popping off at the end connecting to the rear suspension arm.
#2060
The b4.1 has a similar problem. The fix for the b4.1 is 2 fold. The plastic piece that screws onto the shock shaft has one side of the hole for the ball larger to make it easier to push the ball through. If the Sakura has something similar mount that side facing away from the a arm. Second, put a 1mm ball stud shimm between the screw head & the ball. That should solve the problem.
#2061
Thanks Waflet I hope that does the trick for me
#2062
hey guys need some help .
i need advice on a Pinion gear im going to be running over a wcrc i say high traction .
my set up
17.5 REEDY Sonic
Tekin ESC
STOCK spur . 38t
my set up
17.5 REEDY Sonic
Tekin ESC
STOCK spur . 38t
#2065
will 80 spur 40 pinion 48p fit? with vert motor mount?
#2066
#2069
im running a 74/37 combo in a vertical mount and the pinion clears by a hair but it works.
#2070
Hi there,
I have just registered as I am in the process of building an S to go racing again after a few years break. All going well but just can't get the diffs to seal. They either leak from the screw heads or from the case itself if not tight enough but if I tighten too much the diff won't move. I'm a bit stuck on what to try next. Any ideas?
